Strup Header
So i installed my strup header yesterday with the weapon r cel elim. Have a ? at first it smoked for a bit and smelled like gas really bad. Is this normal? today it didnt smoke at all but off and on it smells like gas a little yet. This a normal thing till the computer adjust to the header? No cel came on as of yet so we will see.
Now my other issue i have a rs7 with the TRD muffler. I was hoping that installing the header would make the exhaust note a little better but dang hardly no diff than what it was. I have friends with tc's and trd mufflers that sound great and a friend with an xd and a trd muffler that also sounds great whats the deal with this muffler!!! |
its new and hasnt been blown to crap yet with exhaust gasses???
smells cause the metal of the header is getting hot for the first time
Originally Posted by fireyrguns
(Post 3530384)
i have the strup and the trd exhaust. it constantly smells like gas. without the main cat it doesnt filter anymore so it will smell that way. i only smell it at a cold idle.
as for the trd muffler there is a minimal difference and thats normal because there is a very large resonator/muffler in the mid-pipe. take it out and it will be louder. |
Just remember to install a new cat if you remove the scuba tank. Running around without any cats is irresponsible. Besides, if you remove the scuba tank, you'll need something there or it will be too loud. A hi-flow cat will sound as good as or better than a resonator.
You guys are great !!! Thanks for all the info ...
Your car should get a little louder over time. I remember when I installed 2 different exhausts on my tC it sounded completely stock for the first day. And then the next day it was very noticeably louder and sounded nice. Your increase in exhaust flow from the header will "break in" your TRD muffler even more.
Yup it's starting to sound a lil better already.
I wanna the strup header but i live in cali and what do i do about removing the origi al cat will i have to remove the scuba tank and replace it another cat? What about the 02 censor with that go on the header?
The scuba tank cat does not get removed. The upper cat on the stock header is deleted.
There are 3 OT sensors, one before the first cat, one after the first cat, and one somewhere by the scuba the first O2 just needs to be put on the header. The second you will need to use a cel eliminator |
Are you using an s pipe? If not, you should be
Originally Posted by streetxdreamer
(Post 3542682)
And why should i be using an s pipe?
Originally Posted by miketf1
(Post 3531164)
FYI, the mid cat/resonator (scuba tank) ain't the biggest problem with the stock exhaust, IMO. It's the 1.8" ID pipe between the scuba and the axle-back. I used to think it was 2.25" until I removed it, then I guessed it was 2" until I measured it. Why 1.8" instead of 1.75" I don't know but I measured it with calipers so it is what it is... way too small.
So i see the cxr S pipe on ebay for 99.00 but its 3" will this help or should i stay stock s pipe?
(Post 3556087)
Originally Posted by mudvayne2k6
(Post 3542603)
don't hate... just tossin' that out there to maybe save you a big chunk in tickets/fines. |
(Post 3556087)
