No start, no crank with humming/buzzing sound
I’ve been having this issue with my 2008 Scion xB, which is the no start, no crank with a humming/buzzing sound. I bench test the starter vs the new starter and the new starter was stronger, so I replaced the starter and I still had the same problem. So, I did a little more research about testing the wires and found out that I have a bad ground somewhere. So, my quick fix was to ground the starter directly to the battery and it started right up. I will order some ground wires and replaced them all in the near future, but for now I’m happy it’s running again. I hope this helps those with the same issues.
