VSC, ABS and Traction Control Lights on..
My Scion xB 2009 with 87k miles has had its ABS, Traction Control, and VSC lights come on only on sometimes and my engine maintenance pops up constantly (I’m pretty sure that’s because of the evap) not sure what the VSC, ABS, and Traction Control lights are though.
The only codes that pop up are related to the Evap system and didn’t know if that could be the case. I also have some big speaker modifications if maybe that could be the issue but I don’t know how that would be related if anyone has any ideas let me know.
Sticky How To Advanced Search SL (Scion Life)
______________________________
Last edited by MR_LUV; Nov 3, 2020 at 08:09 AM. Reason: Moved to Correct Forum by Administrator
Since all those codes reference the Vacuum Pump Module I would start with a visual inspection of it and make sure all the connectors are clean, tight and not damaged. It is located under the rear of the car just behind the gas tank. The module is actually mounted to the charcoal cannister.
Subcompact Culture
Aug 8, 2009 05:29 PM
bluexbox916
10
Jul 23, 2008 02:40 AM
syring65
Aug 29, 2007 01:04 AM
