Water Pump Failure Poll
This poll is intended to collect factual data on the XB's actual water pump failure rate. Your vote is public so others can see how you voted. Please vote honestly and don't use this poll for other agendas. TIA.
2008 xB had the tell tale sign of the pink line on the underside of the hood, leaking pump confirmed by a Toyota tech at the dealership, and then replaced under warranty at 47,239 miles. We'll see how the 2012 does.
1 Attachment(s)
I have a 2005 tc but also have the water pump problems. I'm only posting because I believe it is the same engine and water pump. Failed the first time at 49,000 miles. The second at 81,000. It was covered the first time under warranty. The second time it was a $300+ bill.
Replaced two One in the '08 , one in the '09 , both under warranty.
had mine replaced on my 2007 tc at 36k on my 2006 tc at 54k and my 2009 xb at 34k lol. lets hope they last lol.
That's crazy....
How one model has huge problem while other models with same motors aren't getting this problem as little to none. I have put 235k on a tC. I never once had this problem. Since I just bought a 12 box: I hope I have the same luck. |
Mine started leaking bad at about 60k, right before i started my engine build. At 52k miles, not one drop.
Also it really does not matter what car you have, all water pumps connected to the 2.4l and most of toyotas are not the best in the world. I have stated on here before that if toyota has one fault its their water pumps. I work for toyota have for 5 years so i see why they come into the shop. However i would rather have a 150 Fix vs thousands and if thats the worst thing i have to worry about im laughing.
this^^^ both my tc's and xb have the 2.4L
My pump just started spraying on the under hood, 57k.The dealer said it is not leaking enough to be replaced at this time.:mad:
If you have the pink line under your hood, then it needs to be replaced. Go to another dealership, or call Scion so that they can instruct the dealership you went to on filing the warranty claim.
Originally Posted by CIONIDE
(Post 3988953)
Any way to add vehicle year to poll? I (should say the wife) has the 2010 RS7 xB and have not heard about anyone with that particular year with a water pump failure...
I have noticed a WHITE line under my hood, passenger side. Not PINK but it troubles me figure I should take it in just to be safe. Coolant is a hair low but haven't ever noticed a coolant smell. 2009 w/45000miles
(Post 3988490)
'08xb
Never had problem at almost 147,000 miles.
Water pump failed today @147. First time since purchasing my baby. Much...much easier than my '02 V6 Passat. Getting one from Pep Boys tomorrow.
Mine had let a little coolant out around 30k but hasn't ever since...or at least my coolant level is ok and there's no splatter from it under the hood.:confused:
