WTB 2008 xb engine
some body help me to get an engine for my 2008 xb,call me @ 561-389-8738,thanks.:pray:
How about telling us what happened to your other motor...:ponder:
The engine still in the car,the only thing i know is that it's locked up.
Well the reason I asked was because I know this little 2.4 is a reliable motor and I haven't read much about them failing. That's the main reason I purchased this vehicle...
I wanted to know what specifically is wrong with yours. Locked up to me means that the crank won't turn. If that's the case then have you had it looked at my a mechanic to see why it's "locked up". Did it overheat or run very low on oil. Is it timing chain related? Have you tried removing the plugs and turning the crank by hand?... Also what's the history of mods and miles on the motor? I would assume if it's locked up, that it led a hard life... Anyways, good luck with your motor... |
Originally Posted by KoolBox
(Post 4013839)
well,i think i know what happen,it was raining a lot,and got in a big water poddle,maybe i got some water in the engine,i will take it to the dealer on monday to see whath they say,wish me luck.
Originally Posted by _Boat_
(Post 4013846)
I wanted to know what specifically is wrong with yours. Locked up to me means that the crank won't turn. If that's the case then have you had it looked at my a mechanic to see why it's "locked up". Did it overheat or run very low on oil. Is it timing chain related? Have you tried removing the plugs and turning the crank by hand?... Also what's the history of mods and miles on the motor? I would assume if it's locked up, that it led a hard life... Anyways, good luck with your motor... Also the 2.4 eats water pumps |
Originally Posted by journeyforce
(Post 4014533)
I am not sure if Toyota made some mods to the 2.4l engine in the 2008- present XB but if you type 2.4l Camry and head bolts stripped, you will get page after page detailing the issue the 2.4l engine with this(basically 3 of the back headbolts strip themselves out over time and take the threads of the block with them.
Also the 2.4 eats water pumps I also read that the rear rotors are a dealer only item...:roll: well,i think i know what happen,it was raining a lot,and got in a big water poddle,maybe i got some water in the engine,i will take it to the dealer on monday to see whath they say,wish me luck. |
(Post 4014499)
Factory intake.
(Post 4014659)
Factory intake.
[quote=_Boat_;4014561]I'll be sure to tell that to my buddy who got 300,000 miles out of his...
I also read that the rear rotors are a dealer only item...:roll:[quote] Hard to believe that hardened carbon steel studs could ever pull out of cast aluminum... :roll: This is surely exclusive to the 2AZ-FE and crappy Toyota products! Thanks... :) |
