09 xB - AEM FIC - Help
I am looking for a base map to run after i hook up the AEM FIC today. Everything will be stock for now. I want to make sure i install the FIC before i move on to the rest of the project and would still like to drive the car this week. So any help would be great. So i am just assuming i need a map?
Thanks. |
I also need to know if i need to do the resistor mod, and i cant seem to find which wire i tap in to for the MAF sensor. Also for the resistor mod it seems you need 2 cam + and 2 crank +. which i dont know where those are either. any help would be great.
Put your resistors on the fic flying leads. Use the fic bypass harness and you wont need any tune for stock, it will run on your stock ecu. There is a sticky wich has a link to wich connectors u need and pin as well as wire colors.
For your resistor mod, there is a sticky over in the TC forum that shows you how to do it, and with all my wiring I did, I just got it off the sticky on our forums. Good Luck
Thanks for the most part it's done. I will post some pics as I work my way through the rest of the install. The sticky was amazing. saved my life for sure. so thank everyone for that. i hope to start the rest of the install on friday after work and work through the weekend.
thanks again. |
