Hi-flow air filters for the 2012 xb questions
After hearing from a buddy that this would help gas mileage I would like to replace the stanard air filter with a K&N filter.
Sooo....
Is my buddy correct about the extra MPG?
I also heard that the the oil from these type of filters can cause the sensors to go bad in the air intake.
Any suggetions on other air filters out there?
Sooo....
Yes, the filter is high flow, meaning less restriction, and smoother intake air flow. However, this won't help with gas mileage as much as one might think. If a quarter mile a gallon improvement is better gas mileage to you, Clang, then yes it does improve gas mileage, but don't count on much more. Just get the K&N and be happy with your drop-in modification. And no, your sensors will not go bad because of the oil(??). If there is an oil, it will not cause a problem.
I highly doubt that a K&N air filter will actually increase your mpg any but it might add a hp or 2 at high rpm. It's more of a "feel good" mod with some potential cost savings since you can re-use the K&N indefinitely by cleaning and re-oiling it. OTOH the K&N doesn't filter as well allowing larger dirt particles and silica dust to enter your engine.
The filter oil won't damage your sensors (mass airflow specifically) but you may have to clean the MAS more often. The jury is still out on this.
Sooo....
Sooo....
I am using a throttle body spacer from Airaid and I love it, I am using it in combination with the K&N Typhoon short ram cool air intake.
Sooo....
Sooo....
cid_mcdp
Jan 5, 2015 02:45 PM
Godfryness
Jan 2, 2015 11:18 PM
hotroddelux
Dec 3, 2014 11:33 PM
