WR Sheet Metal Race Intake Manifold..
this would be sweet if they going to make one for the xb2
same engine and same clearance. they posted it up here cause it is probably going to fit into the xB2
sounds good know when is it coming out and how much it going to cost
read the other thread.... and you have to realize its still in development. weapon-r unlike other companies likes to be active in forums and tells us what they are doing... wait and be rewarded.
Originally Posted by WRLEO
We should be looking at $600-650
thanx i'll try to wait patiently. well i know weapon-r always take their time to create a good/great products like what they did w/header and s-pipe great stuff. even their cel eliminator its a really good product too. ever since my header and s-pipe installed for over 1500 miles constantly going 75+mph twice going over 100mph and still no cel. just luving it
would rather get the golden eagle for that price
would it fit and where do they have it in stock?
I believe the golden eagle one is still in production and is for forced induction apps.
that sucks i'm looking for n/a
Well by the pics of the weapon-r one I think your in luck. It has pretty long runners, should be good for NA.
yep but still no updates. really can't wait till they have one out
have you been keeping up with the other thread?
WR needs someone in the area w/ some kind of engine management to continue testing the intake manifold. |
if i have one i would do it
golden eagle just have one
any updates?
any new info would be great |
PICTURES OF THE NEW VERSION... ( PRODUCTION PIECE )
NEW FEATURES: 1. NEW PLENUM SHAPE BETTER FLOW AND FITMENT 2. LONGER RUNNERS FOR MORE TORQUE AND LOW-TOPEND RANGE POWER 3. LARGER VELOCITY STACKS FOR HIGHER FLOW 4. ALL AIR NIPPLES ( SAME AMOUNT & SIZE AS STOCK ) 5. TIG WELDED TO HOLD UP TO 35LBS. 6. PLENUM IS MADE OF 4MM THICK ALUMINUM 7. BRACKET FROM TB TO HEAD FLANGE TO ELIMINATE STRESS CRACKING FROM VIBRATION 8. GOOD FOR NA AND FI SETUP'S. https://i223.photobucket.com/albums/...D/DSC_1463.jpg https://i223.photobucket.com/albums/...D/DSC_1465.jpg https://i223.photobucket.com/albums/...D/DSC_1466.jpg https://i223.photobucket.com/albums/...D/DSC_1467.jpg https://i223.photobucket.com/albums/...D/DSC_1468.jpg The VELOCITY STACKS that we use inside the Intake manifolds.. https://i223.photobucket.com/albums/...D/DSC_1477.jpg |
:shock:
dang that looks sweet pm sent |
JUST FYI.. This was taken from ENGINEBUILDERMAG.COM
Runner Length: Runner length also affects the rpm range where an engine makes the most power. Longer runner lengths have a “ram” effect that helps keep the air moving forward as the intake valves open and shut. When an intake valve opens, there is a short lag before the cylinder starts to pull air through the runner into the combustion chamber. A longer runner helps maintain the inertia of the air column so it will fill the cylinder faster. When the intake valve slams shuts, the momentum of the incoming air hits a roadblock, and a pressure wave rushes backwards through the intake port and runner. A longer intake runner tends to keep the air moving in the right direction in spite of the reversionary pressure pulse that is trying to push it backwards. Shorter runners, on the other hand, usually flow better at higher engine rpm. Reducing the length of the runners may allow the engine to make more power at the top end, but the trade-off may be a loss of power and torque at lower speeds. When choosing an intake manifold, therefore, the runner length should match the engine rpm range where the engine is built to make the most power. If you are building a low rpm torque motor, you want an intake manifold with longer high velocity runners. On the other hand, if you are building a high revving motor, you will probably want a manifold with shorter runners or runners with a larger cross-sectional area to flow more air. Link to this article.. http://www.enginebuildermag.com/Arti...d_to_wild.aspx |
