Automatic Door Locking and Unlocking
Trying to set my locks to where they lock with speed and unlock with the drivers door.
Following the steps ON position Neutral Holding down unlock / lock for 5 seconds within 10 seconds of turning on Not working. Any input? |
Figured it out, you have to cancel the current mode, THEN program the new mode.
The door lock with speed is nice, about 13-14mph. If you stop, someone gets out, then go again, the door relocks. Unlocking with drivers door is nice, because it only unlocks the whole car if its turned off, so if you get out and leave the car running, the drivers door is the only one unlocked. In the stock mode, the lock with drive was nice, but IMHO unlocking all doors in park is unsafe. |
Do you want to describe exactly how it is you're doing this?
Its in the front part of the owners manual, there are steps for setting lock mode to either lock the doors in any gear other than park, or lock them over 12 mph.
Unlock modes are either when its put into park, or when you open the drivers door when the car is off. |
I dont have an owners manual :-(
To turn lock with gear selection on/off:
turn key to on hold down the lock button on the drivers door for 5 seconds, then release. to turn on/off lock with speed: turn key to on move gear selector to neutral hold down lock for 5 seconds To turn on/off unlock with gear selector: turn key to on hold down unlock for 5 seconds then release To turn on/off unlock with drivers door: turn key to on place car in neutral hold down unlock for 5 seconds if the code takes, the locks will cycle after you release the button. Once you turn the key to on, you have 10 seconds to press and hold the lock/unlock key. Also, you have to turn off whatever mode you are in, before you can turn on the new mode. This was my first mistake, and I could not get anything to change. |
thank you very much!!
edit: i just tried it but nothing happened. tried all of the codes at least twice, there was no confirmation by the locks cycling. |
Hmmm. Ill have to check my manual tonight and make sure I typed all the steps right (did it from memory)
Or, just go to dealer and have them hook up computer and do this for you. supposed to get this one time for free, i have mine where when i turn off car, and open just drivers door, only that door opens, and it locks when i hit 11ish mph. i also turned off the beeping for the seat belt, only flashes. you would be amazed what options you can mess with.
Im surprised they would do it for free, most dealers charge for stuff like that. There is also the trouble of taking it in, when I did it in my garage in 5 minutes.
Andrey, did you turn off the current setting (lock and unlock with gear selector) before trying to turn on the new setting? You cannot jump from one feature to the next, the current must be turned off first. |
I tried to do the steps for turning off the locking when u shift out of park -
To turn lock with gear selection on/off: turn key to on hold down the lock button on the drivers door for 5 seconds, then release. After I held the button for 5 seconds nothing happened...so I tried all of the other things on there to see if I would get any confirmation for ANYTHING but nothing happened. I need to get my hands on a manual, the beeping with the seatbelts is annoying! I put my backpack on the passenger seat all the time, and it's heavy enough to think that there is someone sitting there. |
Locking linked with shift:
All doors lock when gear selector is moved out of P position Locking linked with vehicle speed: Doors lock when speed is over 12 mph To select or cancel vehicle locking linked to gear selector: Close all doors and turn switch to on leave selector in P position Within 10 seconds of turning ign on, hold drivers side lock switch for 5 seconds and release To select or cancel locking linked with speed: Close all doors and turn switch to on Put selector in N position Within 10 seconds of turning ign on, hold drivers side lock switch for 5 seconds and release Unlocking linked with shift position: All doors are unlocked when selector is in P position Unlocking linked to drivers door: All doors are unlocked if drivers door is opened within 10 minutes of shutting engine off To select or cancel vehicle unlocking linked to gear selector: Close all doors and turn switch to on leave selector in P position Within 10 seconds of turning ign on, hold drivers side unlock switch for 5 seconds and release To select or cancel unlocking linked with drivers door: Close all doors and turn switch to on Put selector in N position Within 10 seconds of turning ign on, hold drivers side unlock switch for 5 seconds and release |
The "selector" is the gear selector...right? I'm going to try this again tonight after I get off work. Thanks for the detailed instructions!!
Yes, it is. No problem at all.
Does anyone know how to turn off the car horn honking after I unlock all doors?
My xB2 didn't come with a manual :doh: _______ |
Just tried it again, worked perfectly! Not sure what I was doing wrong the first time though.
What are the instructions for making the seatbelt not beep? |
I have not seen that one.
(Post 3096155)
Originally Posted by boooosty
(Post 3099155)
When I drove a Matrix, there were instructions on how to remove the seatbelt beep and it worked perfectly. I tried on the xB2 and didnt work.
| All times are GMT. The time now is 01:10 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
