burnt bulb
The bulb behind the air directional knob burnt out and was wondering how easy it is to replace myself, and what needs to be taken apart to acquire access to it.:eyes:
If I remember right:
-Pull stereo bezel straight out -pull trim piece right below bezel out -lift dash up just to the left of removed bezel and trim hole (lift till clip comes undone) -pull up on shifter plate/panel from the rear (closest to e-brake) -remove shift knob and plate -remove 2 screws on either side of climate controls -remove climate control panel -on the back side of knob use a small flat head screw driver to undo 2 or 3 small clips (be real careful you don't brake them) I think that's all...hopefully someone will chime in if I'm wrong. Please do this at your own risk. - |
