Fuse tapping
Old Dec 16, 2011 | 01:43 PM
11ScionXb's Avatar
Default Fuse tapping
Hello... I will be installed in a whelen air horn & pa on my XB and I would like to know if any of you guys have used fuse taps and which fuse would be a good one to tap into?
Thanks!
Old Dec 16, 2011 | 07:17 PM
stankyrice's Avatar
I fuse tapped my remote wire to my amp, you can buy a fuse tap at your local auto parts but mine cost me about $7. I said screw that so just pulled out the fuse and stripped and wrapped the wire around the fuse and plug it back in. Works like a charm. ^^
Old Dec 16, 2011 | 08:34 PM
11ScionXb's Avatar
I purchased a fuse tap "add-a-circuit" I just dont know which of the fuses in the fuse box to tap.
Old Dec 17, 2011 | 04:48 AM
c500129's Avatar
I bought that too for my interior LEDs in my tc. There are empty slots in the fuse box inside the car that have power running throw them. I put a fuse in the add a circuit and tested them out to see which one works. I believe the owners mamual tells you which ones work, dont quote me on that though.
Old Dec 17, 2011 | 06:54 AM
stankyrice's Avatar
I avoided that "add a circuit" because I couldn't justify that for the amount it cost. But if you looked in the car manual towards the back, it should have a diagram of all fuses, one under the hood and also the one in the cabin. Look for one that says horn or something and tap it into there, it might be a relay instead, I'm not sure, I have a Tc.
Old Dec 18, 2011 | 07:32 AM
11ScionXb's Avatar
Yes I checked my fuse box and there are empty spaces with power running through them now I just have to go buy a fuse tomorrow I forgot to get an extra for the add a circuit :s hopefully it works
SloTC1
Aug 16, 2018 02:45 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
DannyBoy65
Sep 21, 2015 06:23 PM
spharr62
Sep 20, 2015 01:44 AM
ScionLife Editor
Sep 15, 2015 04:40 AM
