Hot wire for to power a backup camera in the trunk door?
I bought a backup camera and installed into one of the license light hole, but I can't find any (12v) hot wire to power the camera? I checked every wires with my DMM, but there are no wire with power.
Anyone can help?
Do I have to run it all the way from the front of the car to the trunk and the backdoor? If yes, do I run it from the top or the bottom?
THANKS
Anyone can help?
THANKS
If you want constant power then you can get it at the hatch light but I suspect that you need a switched power source which you will need to go to the front of the car for. It is possilbe that you can use the reverse wire if you only want it to be powered when the car is in reverse, you can get that at the harness on the drivers side going to the taillights for the 2011-13 or going to the bumper for the 2008-10.
airmankevin1
02-14-2018 01:23 PM
clickclickw00t
02-18-2015 08:57 PM
