Please HELP! Console lights aren't working
Old Feb 22, 2015 | 04:26 PM
2008ScionXbGold's Avatar
Default Please HELP! Console lights aren't working
The lights on my AC controls, gear shift indicator, dimmer switch for the dash lights and the buzzer that tells you that you left your headlights on are NOT working. I am going crazy trying to find it and my battery has gone dead twice because I have left my lights on. Can any body help? I figure it's probably a relay but don't know which one.
Old Feb 23, 2015 | 06:53 PM
Greg S's Avatar
Have you checked the fuses both under the dash and in the engine compartment?
Old Feb 25, 2015 | 02:32 AM
I have looked under the hood but can not find any fuses inside. I can only find relays. I have stopped at 2 dealerships but no one will help me.
Old Feb 25, 2015 | 07:08 PM
Greg S's Avatar
Check the main fuse box under the dash on the drivers side. There is most likely a blown illumination fuse in there.
Old Feb 25, 2015 | 08:49 PM
Thanks I'll check there.
Old Feb 25, 2015 | 09:32 PM
I did finally find the fuses but none that say anything about illumination but I did find one that says panel....any thoughts?
Old Feb 26, 2015 | 02:47 AM
That was it...Thanks
Old Feb 26, 2015 | 07:07 PM
Greg S's Avatar
Your welcome.
Old Jul 16, 2016 | 04:49 AM
Manny22's Avatar
Im having the same problem how can i fix it ??
Old Jul 19, 2016 | 11:10 AM
Vfxb2's Avatar
Manny22 the original post was quite some time ago. i suspect it was a blown fuse under the dash (there poorly labeled) i recommend testing all the fuses. if you don't have a fuse tester then pull each 1 out 1 at a time and look through them with a light (please put it back before pulling the next one so you don't mix them up).
Old Jul 21, 2016 | 04:11 PM
08SUPERWHT's Avatar
Wow I feel like an idiot. None of those lights have worked in mine since I bought it. I figured Scion was just lame and didn't have lights in those locations.........Looks like I will be fuse hunting tonight
Old Aug 15, 2016 | 10:50 PM
08SUPERWHT's Avatar
Not sure if you already fixed it or not, but I finally got around to fixing mine. As previously stated, they are poorly labeled. But the fuse that was blown on mine was in slot 17, labeled as (Panel).
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
TheTripleC
Jan 4, 2015 06:46 PM
LeChuck
Dec 9, 2014 02:26 AM
randode
44
Jun 29, 2004 04:19 PM
