Scionlife.com
Scionlife.com (https://www.scionlife.com/forums/)
-   Scion xB 2nd-Gen ICE & Interior (https://www.scionlife.com/forums/scion-xb-2nd-gen-ice-interior-1794/)
-   -   Rear door panel removal to get to licence plate lights.. (https://www.scionlife.com/forums/scion-xb-2nd-gen-ice-interior-1794/rear-door-panel-removal-get-licence-plate-lights-233416/)
Frederick 01-13-2017 01:34 AM
Did a lot of searching and found nothing on how to remove the rear door panel on 2010 xB.
I have a lighted license plate holder that I want to hook into the plate lights.
Any help or advice on wiring would be great and much appreciated.
______________________________
Greg S 01-13-2017 06:31 PM
Grab and yank. It's just held on with clips. Start in one of the lower corners and work your way up.
Frederick 01-14-2017 01:14 AM
Wow, thanks that was actually easy to remove. Now the black and red wire coming from the plate frame, can that be wired directly to the plates lights wires that are green and white and what is the green, positive or negative?
Thanks...
Frederick 01-14-2017 04:52 AM
Done and done..
DownsizeToOrganize 07-17-2018 08:27 PM
Thanks...
What was the final answer to what the green wire is?
drizzoh 07-17-2018 10:00 PM
Green is likely the positive, but tap it and find out if it works for your application. If not, tap the other :) 50/50 chance.
Greg S 07-18-2018 06:42 PM
Since white is always ground in Toyota cars the green is the power wire. Also, the parking light wiring is green so yeah, green is positive.
DownsizeToOrganize 07-18-2018 06:52 PM
Thanks for the followup.
SIT 09-20-2018 09:32 AM
Wow, white is ground, good to know.
