Scion xB 2011 Door/Alarm issues..
Old Jul 27, 2015 | 12:16 PM
wejarrell's Avatar
Default Scion xB 2011 Door/Alarm issues..
I have no idea what is wrong with this thing. The front 2 door locks do not work with the remote or the internal buttons, the back left works when the car is put into drive or reverse, but not the remote and not on the internal buttons, and the back right works sometimes for all but sometimes not, meaning I have to check every door before I hit the lock button to set the alarm. Also as of late the alarm will go off when I put it from park to drive if I lock any of the locks manually, and It will not stop unless I turn off the whole car, remove the key, lock and unlock it a few times and then I can start it. This is my first and most likely last Scion due to the constant issues but I figured before I jut get rid of it I will seek advice from the forum.
_____
Old Jul 29, 2015 | 06:21 PM
HATEnFATE's Avatar
aftermarket alarm system??
Sounds like a junk alarm system but not knowing what you have, i can't really comment on it..
Don't blame the car, blame the system..
Old Jul 29, 2015 | 06:58 PM
Greg S's Avatar
I'm with HATEnFATE, it sounds like the alarm was installed improperly/poorly or someone has messed with the electrical at some time.
Old Jul 29, 2015 | 08:29 PM
wejarrell's Avatar
Default Thanks
Thanks guys. Everything on the car is stock, the alarm was put on by Scion.
Guess I am heading to the Scion dealership to give them one last try to fix it.
____
Old Jul 30, 2015 | 02:18 PM
HATEnFATE's Avatar
Do you use the factory key remote to activate and deactivate the alarm or is there an additional remote?
Old Jul 30, 2015 | 03:44 PM
wejarrell's Avatar
Factory only, but as stated it isn't just the remote that is failing, it is the internal door locks and the putting it in drive and park, except the back one.
Old Jul 30, 2015 | 07:00 PM
Greg S's Avatar
Quite possible that the door lock module is failing and needs to be replaced.
Old Aug 2, 2015 | 12:14 PM
rjjone2's Avatar
I am having a similar issue on my '08. A few years ago, my rear driver side door lock would randomly not work when using the key fob to lock or unlock the doors. I was thinking it was the actuator but then just recently I started having issues with the two front doors as well. Some times one or more will not lock and when I put the car in drive I can here the actuators fire several times trying to lock the doors. I was prepared to replace all of the actuators but now GregS has me thinking it may be the module. Any info on where that is located?
Old Aug 2, 2015 | 12:27 PM
rjjone2's Avatar
Ok after looking at the wiring diagram, it looks like the individual door actuators are wired directly to the ECU, no intermediate module that controls all 4 that I can see. This either means that I randomly had 3 start failing within a few years of each other or I have a larger issue with the ECU. Troubling.
Old Aug 5, 2015 | 08:33 PM
rjjone2's Avatar
After a brutal 2 full days of work, I'm happy to report that I've fully refurbished the motors in the three lock assemblies that were failing. After attempting a fix with a universal actuator kit which ended up not working, I found a DIY outlining the motor refurbish procedure and decided to give it a shot. It was painful to learn how to do it on door 1. Getting the lock assembly out of the door was hard and then you have to crack into the assembly housing to extract the motor that drives the lock cable. Incredibly, it is the simplest little hobby motor that you would find in a kids toy. I guess after years of use, the contacts on the motor build up carbon and the commutator stops moving. So cleaning the contacts fixes the issue. Then it is super painful to get the motor back in and get the assembly to function properly. There are a ton of little levers, gears, springs, and clips in that thing that can get all jumbled if you are not careful. Anyway, my dad and I knocked out three of the doors and I'm not having issues any more.
Here is the DIY I followed:
DIY Gen 2 Power Lock Actuator Repair. Cost $0! - Scion xB Forum
__________________
Old Aug 5, 2015 | 09:19 PM
HATEnFATE's Avatar
SUPER!
JonnyHomesick
Aug 31, 2007 06:50 AM
xbc
9
Sep 22, 2006 01:30 AM
tCarloRS1_0
11
Dec 23, 2005 10:56 AM
dischinezeboi
13
Aug 17, 2005 12:07 AM
elwood58
Aug 12, 2004 04:11 AM
