Scion xb 2015 Interior Sill LED
Old Aug 21, 2024 | 12:14 AM
thekyoshi's Avatar
Question Scion xb 2015 Interior Sill LED
I got this off Amazon for the sill
OEM
Amazon Amazon
I was wondering, not a huge deal if it doesnt fit, I can return it
but did anyone attempt to install it for the scion xb 2015?
even though it's through 2008-2011
‎PTS21-52080
Thanks
Old Jan 24, 2026 | 05:56 PM
mr2spyderman's Avatar
I’m trying to install a set I bought on eBay. The seller neglected to mention that it didn’t come with the wiring harnesses. Do you happen to have any pics of the wires?
Old Jan 25, 2026 | 07:21 AM
thekyoshi's Avatar
as long as its oem it is fine, it will be tapped into existing wiring under the sill
instruction here
http://toyotaparts.sparkstoyota.com/install/00016-79810inst.pdf
Old Jan 26, 2026 | 04:35 PM
instruction here
http://toyotaparts.sparkstoyota.com/...-79810inst.pdf
Thank you for the installation instructions. I'm still struggling to figure out how to:
1. Gain a better understanding of how to create a custom wiring harness to install using the instructions
or
2. Locate new points to wire the sills
Have you read the instructions? Do you think the negative wire connects under the dash and the positive wire connects to the B-pillar?
Old Jan 30, 2026 | 04:34 PM
thekyoshi's Avatar
I cant really help you with the wiring install as I took my scion to the autoshop and they installed it for me. Sorry.
Old Jan 30, 2026 | 05:39 PM
Greg S's Avatar
or
Other way around for the connections. The door pin wire they list being used is a negative trigger and the white/red wire in the kick panel is a constant power wire. No real need to make a custom harness unless you want to make it easy to unplug. You can just run the wires directly.
ScionLife Editor
Jun 28, 2015 01:00 PM
NonStopTuning
Jun 19, 2015 04:41 AM
alank2
Jan 23, 2015 01:17 AM
scionxbpr
Oct 21, 2013 09:32 PM
scionxbpr
Oct 21, 2013 03:37 PM
