single sub suggestions.
I want to run only a single sub in my xb. My amp is a Memphis Belle (sub channel is 1100x1 at 1 ohm).
I am looking to run a sealed box and a very versitile sub (I listen to just about every kind of music), I'm not looking to shake the car apart, just nice tight bass that can go reasonably loud. What sub would you guys reccomend? My budget is arround $600 for the sub. Thanks! -JB |
I would suggest a Jl 10 or 12 w6, Like yourself I like tight bass and I run 3 8w3v2s. Ive also heard good things about the image dynamics IDQmax subs. I have no clue what I would change to if I wanted to go with one sub...hopefully this helps alittle
-nick |
I had an Alpine Type-x that sounded awsome than traded with my monther and now have her JL Audio W7 From her 02 explorer.
https://i49.photobucket.com/albums/f...cture007-8.jpg https://i49.photobucket.com/albums/f...sty69/JLW7.jpg Im gonna sell the Type X and give my mom back her W7 and look into a W6 cause the W7 is one nasty SUB!!!! Im very happey with both companys and this is my first time running one sub and i dont think im gonna run 2 no longer cause when you have the right sub one is def all you need. |
600 on just a sub? just how "tight" does it need to be. I just bought a rockford 10" and it's more then fine.
Thanks for the input guys! I was thinking a w7 but with the 3ohm load I won't have enough power. I was thinking of a w6 because of the DVCs. I might just buy one to try it. I like the single sub because 1 quality sub sounds damn good and saves space and weight.
My other thought was a pair of 8w7s but I don't know how the 8s sound. The only local JL dealer is a prick so I'm not going to him for a listen. Drew, that last pic is sick! I like the just out of focus background and the storm rolling in. -JB |
-JB |
Id love a pair of 8w7s in a sealed box you would need all that power.. Ive hear one in a ported box with only 350rms going to it. it rocked, but was to boomy for me... in a sealed box it would slam much more controlled.
-nick |
1 kicker solo barak will take that power and only requires a 1 cu ft box sealed, almost indestructable , moves lightning fast, and hits hard as a mofo, very clean sound
Soundstream XXX 15? :D
I <3 mine. But all due seriousness, check out SSA's XCon line. They just dropped and they should be able to take the 1100watts great! They're less than what you want to spend, too! You'll be able to get a properly designed and constructed enclosure! :D |
And as far as 8's go, the Digital Deisngs 1508 > JL 8W7, IMO. Much less expensive, too.
I <3 mine. But all due seriousness, check out SSA's XCon line. They just dropped and they should be able to take the 1100watts great! They're less than what you want to spend, too! You'll be able to get a properly designed and constructed enclosure! :D An enclosure won't be a problem. A friend has enclosure design software. I'll have him design it and I'll cut it out on a 4'x8' CNC router I use at work. -JB |
CNC router?!?! :tap: I envy you.
SSA's subwoofer line up!!! You could even run an Icon from those guys since you don't want anything that's too incredibly loud. I still recommend running a ported enclosure, but that's me. You can get it to sound good without being boomy. :D |
jl 10w6 would be a good choice for a sub
re xxx. great sub that sounds really nice in a sealed enclosure. it won't slam like a ported but it should wang pretty good.
alpine type r!
I have a JL 12' W6v2 with a ported box it sounds great, I have another JL 12 without box for sale PM if you intereted.
try image dynamics! they have a DVC that is pretty ballsy! you have more than enough power.
This is true, Ive hered some Dynamics b4 and def def ballsy for sure. I beleave it was the iDmax line. I love JL not causae of the name but just the quality, but they are def lees some expensive companys can hold there owen and make amazing products. Im running the JL W7 12 and im switching to the JL W7 13.5 got a good deal and dont wanna pass it up. |
https://i724.photobucket.com/albums/...k/IMG_0104.jpg
here is my single sub from JL Audio |
