Subs under the back seats...
I was wonder if anyone has put subs under thier back seats... I was looking at it and thought it would be a good place to hide some 10's.. anyone have any comments? i am not sure whats underneath it all yet. But i am assuming probably the gas tank...
I have a PS2 and my video distro amps under the seat, it's a bit sung under there, you're not gonna fit 10's. theres about 9 inches of depth front to back and only about 4-5 top to bottom. but it's as wide as the seat if that's a plus
looks like 8's it is... gunna have to be custom..
I dont see any chance of any size sub fitting underneath the rear seat. Depth is not a problem, but the heighth will be a big problem.
Elemental designs actaully make a custom enclosure that fit great right under either of the fron seats. its a 10'' slim sub. http://www.edesignaudio.com/edv2/pro...roducts_id=464
the pattern is full.
Hmmm slim fit 10" ehhh... i might make a custom box kinda like there one that goes over the spare tire... I dont want to take out the spare though...
BTW, for the person that said you can go straight across under the rear seat - not quite true, there's a hump in the middle that you'd have to work with/around. Essentially, your rule for under the rear is 13x9x2 max before you have to cut the seat. (And the 13" has to go side to side, 9" depth is still giong to get a bit of pressure from the seat) |
lvbitwiz, are those the new slim subs from soundstream!? How does it sound? What are you powering it with? Details please!
lvbitwiz, did you use polyfill? It could peak at that frequency because of the box being on the smaller side. The smaller the box, the higher the tuning. The larger the box, the lower. That's why strict SPL guys run tiny boxes with HUUUUGE ports.
The polyfill should help. It'll make the enclosure act larger because it slows down the rear wave of the subwoofer. |
