Scionlife.com
Scionlife.com (https://www.scionlife.com/forums/)
-   Scion xB 2nd-Gen ICE & Interior (https://www.scionlife.com/forums/scion-xb-2nd-gen-ice-interior-1794/)
-   -   tachometer (https://www.scionlife.com/forums/scion-xb-2nd-gen-ice-interior-1794/tachometer-199067/)
mudvayne2k6 Feb 7, 2011 04:26 AM
tachometer
hello has any one tried to install an aftermarket tachometer on the xb2? i wanna install one a monster tach with a shift lift. i have installed one on others olders car but not on the newer models. Should i just tap into the wires in the back of the gauge cluster? or should be tapped into the computer? any help would be appreciated. thanks in advance
my06tc Feb 7, 2011 01:19 PM
just get a shift light
AAG Feb 7, 2011 06:35 PM
Don't do it. Not only do you NOT need it, it's ugly and pure rice. Now if had a drag setup, then I'd see your reasoning behind it.
Greg S Feb 7, 2011 10:34 PM
It would probably be easier to tap the tach line behind the cluster since the ECU is under the hood. Don't know which wire it is though so you'll have to test.
draxcaliber Feb 7, 2011 10:51 PM
the car already has a tach, why do you need a second one?
RedDragons Feb 20, 2011 05:29 AM
dont rice your B up. just get a shift light like said before.
according to directechs...
tachometer | grey | ac | located @ datalink connector, white 16 pin plug, pin 9
you should be able to find the wire on the back of your gauges as well
© 2026 MH Sub I, LLC dba Internet Brands
