Will the airbag go off I don't have a passenger seat?
Old Oct 17, 2012 | 12:27 AM
defuse's Avatar
Default Will the airbag go off I don't have a passenger seat?
Silly question but I removed my passenger seat and I was wondering if I reconnect the ground to the battery and turn on my car will the air bag go off?
Old Oct 17, 2012 | 04:27 PM
ttircuit's Avatar
It shouldn't. It will set the air bag light which will then disable the whole airbag system till the light is reset. I work at Nissan and pull seats out all the time with the car running so I will have ac lol. Just gotta clear the light afterwards.
Old Oct 17, 2012 | 08:33 PM
ttircuit's Avatar
Also wanted to add my xb got flooded a while back and I drove around for over a week with just my drivers seat. No carpet or anything.
Old Nov 21, 2012 | 12:12 PM
TonyGrange's Avatar
Two questions here.
How does one reset the airbag light?
Someone mentioned a resistor installed in the wiring after the passenger seat is removed. What value of resistor & which wires are connected to said resistor?? Colours??
Old Nov 21, 2012 | 01:58 PM
xb2owner's Avatar
I too would like to hear the answer to this. I'm in the middle of soundprooofing the xB one section at a time. Would suck if I plugged the bag back in and wind up getting the pi$$ knocked out of me by the airbag.
Old Nov 21, 2012 | 02:30 PM
TonyGrange's Avatar
Disconnect battery when removing seat. Do not reconnect or switch on ignition while seat is out. If you do switch on ignition while seat is out it will detect a fault & disable ALL the the airbags + the auto belt tensioner. This is not good. You will not blow up any airbag but you may have to spend time & money to have the system reset. I googled that process & found instructions to reset airbag code on a Corolla, very simple. Chances are this might work on all Toyotas. But don't know. H
Old Nov 21, 2012 | 03:40 PM
ttircuit's Avatar
From.my experience with mine. along with almost every car I've worked on. Once you put the seats back in and drive for a few days the light will go out. Mine took about 45 min.
Risen_Son_Racing
May 6, 2005 02:31 PM
TJ
27
Feb 8, 2004 12:20 AM
xvolcomx88
Nov 27, 2003 09:23 AM
