xb2 Stereo install information
I noticed the plugs on the Gen1 stereo and the xB2 were the same. Yes, that's right. The same wiring kit is used for both vehicles. So I yanked the cheap DVD deck out of the Gen1 tonight and decided to put it into the xB2. Everything was pretty straight forward.
The only trouble I had was that part of the side pieces that come with the Metra kit I had to cut them off to fit onto the double DIN bracket. It all fit pretty good... So you can use the old Metra install kit even, you just need to trim off a corner of the bracket (real easy and not cosmetic). http://www.pldlawyers.com/bp/scion/x...ssembly-74.JPG http://www.pldlawyers.com/bp/scion/x...ssembly-73.JPG Here is a picture of the Gen1 stereo on top of the xB2 deck. http://www.pldlawyers.com/bp/scion/x...ssembly-71.JPG |
Dude, take that bag of chips out of the car. No eating or drinking in the car :no:
want'd 2 know does ur new radio allow u 2 use ur steering wheel controls and also does the aux and ipod imports that are stock work also..
http://www.pac-audio.com/products/pr...el%20Interface They just need to be programmed for the type of car and a few wires need to be hooked up. |
thanx on the info, i think'n maybe just stick with the upgraded scion head-unit or "maybe" the avic-d3 any thoughts
Ive done a bunch of D3s in the new xBs as well as my car with Ipod, Blue Tooth, Satellite Radio, SteeringWheel Controls and all works great and looks great.
The Metra kit is a little ehh.. The Toyota kit which metra copied fits better parts numbers are at the dealership |
So basically what you're saying is, the 2008 xB headunits would fit in a 2006 xB?
Dashes are the same on all of the scions the 08 xb uses xA brackets
So basically what you're saying is, the 2008 xB headunits would fit in a 2006 xB? |
If you buy the brackets from toyota they snap right on without any screws. The metra ones need a bolt hole cut off on the side of the radio but so do the old ones. I havent had any problems with all the new ones Ive been installing them on.
