A/C won't blow air..
Old 06-26-2018, 03:59 AM
09xb82's Avatar
Default A/C won't blow air..
I went to Disney world and everything was fine... I went to leave and my A/C won't blow any air. The light where the A/C shows on/off won't respond, the middle dial to turn on the air does nothing. I have checked fuses 16,44, the relay and I even replaced the A/C blower motor.
All that's left is this #21 50 amp fuse that's is in the fuse box under the hood but it's a not a normal fuse. I have no reason to think it's bad by looking at it. The whole link itself is getting power and other things on it are working. How do I know if it's bad before I rip half of my engine apart?
Any other ideas of what it might be? I have a multimeter. I checked the switch itself but that's looking fine.
______________________________
Last edited by MR_LUV; 08-29-2018 at 07:31 PM. Reason: Moved to Correct Forum by Administrator
09xb82 is offline
Old 06-26-2018, 06:48 PM
Greg S's Avatar
Sounds more like the button might be bad. Take the AC controls out and test the button to see if it has continuity when you push it.
Greg S is offline
ShawnMcc
07-11-2015 11:07 PM
HughDTX
07-01-2010 12:51 AM
teknikks
11-11-2007 02:33 AM
handyxbbox
Regional - Desert & Salt
14
03-29-2007 01:16 AM
BrianGillen
10-16-2005 06:23 PM
Quick Reply: A/C won't blow air..
