Antenna
I want to know how is the long rubber antenna attached to the car's roof? I'm trying to determine whether it fell off while I was driving or someone stole it. :cry:
Where can I find a replacement antenna? |
ok.. from the tip of the antenna down to the sheet metal roof... about 8 inches... jh
Actually, I want to know how is the antenna attached to the base? Is it screwed on or is it fixed to the base with a pivot on the bottom?
Ok I looked at the pivot point... NO fasteneers visable.. then looked above the pivot point going up the antenna & saw a seam... So I grabbbed the antenna & 'unscrewed'. Well I unscrewed the antenna all the way off! Now the pivot point remained on the car with the 'male' threaded end exposed. Inside the removed antenna shaft is a threaded 'female' end.... Hope this answeres your question.... jh |
Not a problem. Thanks for checking it out.
I can confirm that some @#$#@$#@ stole my antenna! I always get confused with the male/female ends. Would the antenna shaft's thread look something like this? Also, what's a good replacement for my missing antenna shaft? https://i19.ebayimg.com/05/i/07/16/7c/65_1.JPG Found it here: Is it even worth $50???Link to Antenna |
idk, if you listen to the radio, then I guess you have no other choice but to buy the $50 antenna.
-captain obvious |
http://www.sigmaautomotive.com/FoliaTec/antenna.php
I have the Shark fin on bottom of page. Had to wait but worth it. EXACT paint job and clear coated also. |
I have a shark fin on mine. If you want I will send you mine if you pay shipping. Hit me at tank@tankspaintball.com.
They match the color specifically based on the paint code of the vehicle. Make sure you checka nd get it here if you do not have hte code. I believe codes are in a sticky note above here. Here is a close up shot to help you decide for sure...
https://i174.photobucket.com/albums/...3/IM000288.jpg |
Looks pretty tight. How was the installation? The website was a bit vague on the installation.
I just got the same one straight from VG at SharkfinAntenna.com at the lowest price I've seen.
Click here for pics & install summary :) |
I can confirm that some @#$#@$#@ stole my antenna! I always get confused with the male/female ends. Would the antenna shaft's thread look something like this? Also, what's a good replacement for my missing antenna shaft? |
Thats why i prefer to deal with 2 male ends...less confusion.
^^ Thats what happens when your antenna is too long for one female end.
And/Or when you get lucky enough to connect with a female end that doesn't mind sharing and has trouble dealing with your... "exuberance" shall we say. Appetite for life?
