Loud whirring noise when I turn on the heater
I just very recently purchased a 2008 xb. The A/C works fine as far as temperature and fan goes, but the moment I switch from cool to heat I get a whirring noise. It reaches different pitches depending on how hot or cold it's set to. Is this an electrical issue? I want to know if I can easily fix it myself before bringing it into the shop.
*Edit* The sound is coming from the passenger side behind the glove box (where the cabin fan is located).
The air filter was SO nasty, so I put a fresh one in there. It still seems to be making the noise though. I couldn't see anything else in there, but it's also at a very strange angle. Is it pretty easy to dismount to do a further inspection and cleaning?
Dealership found leaves in mine. Service guy had small hands and was able to feel around and found them. I agree, odd angle. Or if you have a buddy with a Snake Cam. Small camera mounted on the end of a flexible cable with a display on the handle end. Harbor Freight has them on sale for under $100. Come in handy some times.
Just the 3 screws? I can do that no problem! I just wanted to make sure there wasn't some crazy mechanism before attempting. I've faced that issue before in a Chevy Aveo, where there was 20 additional components that you needed to disconnect before accessing anything.
Thank you all for your help. I will update as soon as I dig through it and clean it up.
wayneside
Regional - Pacific Northwest
09-23-2015 10:29 AM
