Problem #2 with my wrecked Scion I bought-Temperature (Outside air thermometer) guage
Old 03-31-2017, 02:35 AM
Natejones75's Avatar
Default Problem #2 with my wrecked Scion I bought-Temperature (Outside air thermometer) guage
Bought a wrecked 2012 xB, about got it back together and done, but not driven it much yet.
On the digital thermometer, the one that says the outside air temp, mine is off. Way off. Says -40 degrees.
Is there a procedure to calibrate this?
Natejones75 is offline
Old 03-31-2017, 04:29 AM
18TTony's Avatar
Not familiar with the second gen xB but I know that most temperature sensors manufactured default to indicate a reading of -40 degrees when they become inoperative.
You can "back probe" test the sensor to see if it is good. You can also back probe the sensor harness to see if it is good. Google it.
18TTony is offline
Old 03-31-2017, 02:56 PM
Administrator
Administrator
MR_LUV's Avatar
Your car was in a wreak.
The Temperature Sensor is located in the Front.
The Chances are High it has been Damaged and you will not be able to "calibrate" it.
I Suggest you consider Replacing it.
Or Order the Sensor and have your Dealer's technician replace it, if it requires wires or plug.
MR_LUV is offline
Old 04-01-2017, 06:58 AM
Default Thanks. I had no idea, where is my wire?
Thanks. I had no idea where it was.
According to the diagram, right in the nose. So mine obviously would have been destroyed.
My question now is where is the plug for it?
There are 2 wires hanging together at the front. I think green and white, plug cut off.
Is that it?
Old 04-01-2017, 02:57 PM
18TTony's Avatar
Not sure what the color of the wires are. But if your ambient temperature sensor is missing, obviously you will need to buy one. You will need to also buy the appropriate connector and splice that connector onto the harness.
It is not possible for a single electrical connector to be plugged into the wrong location. Wire connectors are installed on automotive wire harnesses so that no two identical connectors are close enough to each other to be mismatched to the wrong location.
Look at all the wires behind the bumper....see whats missing or not connected. There should be wires for:
Ambient temp sensor.
Blinker light.
Marker light.
Headlight.
Fog light.
Horn.
Hood latch.
Airbag impact sensor (yellow, don't touch).
18TTony is offline
