Ksport GT Springs Or Tanabe DF210 Springs
I need help on deciding what lowering springs should i get...
the ksport gt or the tanabe df210 for my 2011 XB..
i know the drop rate is almost about the same
but hows the ride quality on both of them?
any suggestions or input will greatly be appreciated!
I know the DFs are awesome... but honestly don't think anyone around has the ksport springs, only coilovers.
I have a set of NF210s Im taking off and putting DFs on soon. The ride is great.
I like mine but if I could Id try out the Tein S or H techs for the stiffer rates. The DF is a good ride but the rear passengers complain of bounciness (but i dont care). I know with the Teins itd be more bouncy New Tokicos all around took care of most of the bounce. Bounce bounce
BOUNCE
BOUNCE
I used to rock Eibach Sportlines and there was absolutely NO BOUNCE. My car was really planted and handled awesome, but I definitely felt those speed bumps resonate through my car.
The sporty handling was amazing, but I switched to NF210s because I wanted a more comfortable ride.
I am more than happy to live down here. I work 12 miles from it. Sometimes after work we ride out there and drive it - makes every bad day a good one.
If anywhere can test a suspension though, the dragon is the place. If you haven't had the chance to come out, you are more than welcome to get a first hand guided tour from me. ;)
So the Ksport GT's are low in the rear, or at least low enough that on a 235/35/19 on a 10w (+25) I cannot roll without rubbing with more than one person in the car. I am deff. going to have to do some fender rolling and modification to make a 10 roll in the rear on these. the front on the other hand may need to settle some more. I am waiting on a set of 35 offset fronts to run, so I will have the same spec with a small bit of camber. I figure the rear would fit much better if I gave it a couple degrees - but as far as front height it doesn't look as low as I think it should considering the rear. I will hold judgment until I get the front wheels on, but on stocks it doesn't look like it will be low enough to match the rear. I will post pics shortly.
I Am still running them currently, but I am swapping them for racelands as I have a negative rake look after 10k. It wasn't bad to begin with, but now it has started to bother me.
I always thought the front could be lower from the beginning. Lately though it does appear to be getting worse. I attribute this to a combination of stock shocks and bad roads though. Mine will be off soon though and I can measure then and see what the sag is if any.
Thanks for your help, I'm trying to get a little more low but dont have the money. i've seen the rake in most of the pics with these springs and it doesn't bother me too much, but i know this isn't something i should be cheap about. Do they ride well? more firm than stock? there's very little info out about these springs.
I would say relatively close to stock feel, although the rears do have a bit more travel than I would have expected, but on stock wheels and tires with a "normal" offset they do not rub.
I personally feel like the fronts need a coil cut to look right. if they were an inch lower in the front the whole car would sit better. I think the problem comes from the front wheel arches being a different shape and a bit higher, so even if the vehicle is level it looks like the front is riding higher.
For my .02, they are a good option if you just want a lowered vehicle and are planning on buying struts at a later date. Otherwise, I would go with a set of coilovers from one of the major brands - I am going with racelands because I have had an excellent experience with them coming from the VW world. They are what you pay for however, and will ride a bit rougher than stock and won't be as smooth as an H&R set. Again, personal preference is key here.
Jayrdee
10-15-2015 03:38 PM
tribe
07-25-2015 05:21 PM
Naughtygoose
07-06-2015 09:59 PM
