18" Jeep Rubicons on XB
Old 07-23-2014, 05:12 AM
autobotguy's Avatar
Default 18" Jeep Rubicons on XB
Hey there folks. I'm looking at a set of 18" Jeep Rubicon wheels for sale locally and they look like they might work for my 2012 XB. The wheels stats are as follows:
18x7 et45
71.5 center bore
My Xb is lowered on K-Sport springs with the fronts cut 80% of one coil . This basically drops the car to DF210 stats.
It looks like with 205/40R18 tires will have a baby stretch and with a 10mm spacer it will be flush without intruding on the suspension side of things. Do you guys think this will work or is even correct??? I'd greatly appreciate any assistance from some experienced folks on here. Thanks!!!
autobotguy is offline
Old 07-23-2014, 05:30 AM
Utah Scions
xseveredveganx's Avatar
I'm assuming it's the JK chassis Wrangler? If so, you'll need adapters. They have a 5x127mm bolt pattern.
xseveredveganx is offline
Old 07-23-2014, 05:35 AM
autobotguy's Avatar
These wheels however are 5x4.5 bolt pattern...sooo probably not JK chassis. Forgot to mention that in the first post. ^_^
Old 07-23-2014, 10:01 PM
Utah Scions
You won't have to run a spacer. You should be fine. You could also run a taller tire if you do feel so inclined.
Old 07-24-2014, 03:41 AM
autobotguy's Avatar
I want to keep the overall wheel/tire diameter close to stock so the speedometer is minimally affected.
Old 07-24-2014, 07:11 PM
Greg S's Avatar
You would be closer with a 215/40 if you want to stick near stock diameter and have more tire choices. Less stretch of course.
Greg S is offline
ScionLife Editor
09-11-2015 12:53 PM
umnitza
09-01-2015 08:06 PM
ScionLife Editor
03-21-2015 03:10 PM
ScionLife Editor
02-25-2015 04:40 PM
eugovector
12-11-2005 01:08 PM
Quick Reply: 18" Jeep Rubicons on XB
