18" wheel - 225/50/18 on non dropped xB 2nd gen
Old Jan 20, 2014 | 06:35 PM
burebistausa's Avatar
Default 18" wheel - 225/50/18 on non dropped xB 2nd gen
2012 xB. manual trans. non dropped (and with no interest to drop)
I am interested on getting 225/50/18 on a non dropped xB 2nd gen. The idea is: #1 to get wheels that will close the gap with 1" (similar to what usually you get when drop and use regular diameter tires), #2 to get some increase on speed (this will give a speed increase of about +5 mph at 60mph), and #3 to flush the tires as much as possible.
Wondering if anyone tried using 225/50/18 and if anyone would have some pics on it. Any advise on what offset to use on front and on the back to bring the tires as flush as possible with no rubbing. Any rubbing concerns?
Also, anyone tried to calibrate the speedometer to correct the speed?
Old Jan 21, 2014 | 01:29 AM
Greg S's Avatar
Offset would need to be about 35-40 in the front with the rear about 10mm more, so 25-30, to be flush. You'll most likely have to use spacers on the rear to even it out.
Old Jan 21, 2014 | 04:18 AM
xseveredveganx's Avatar
Utah Scions
You may be able to recalibrate the speedo, but I haven't seen it.
I don't see how a larger tire will effectively increase your speed, but it will certainly alter your speedometer readings.
Larger tire will also raise rotating mass and potentially decrease fuel mileage. Ride will certainly improve, though!
Old Jan 21, 2014 | 04:23 AM
vancouverray's Avatar
The XB is really jack up in the back . Even with big rubber to fill the gap it will still look high in the rear . Had no plans on lowering mine , glad I did . Rides way better now .
Old Jan 21, 2014 | 04:13 PM
pyroman131's Avatar
REDACTED
Old Jan 22, 2014 | 03:28 AM
vancouverray, your rims are gorgeous. What are the sizes on your tires and on the rims? Please quote the offset if you know it.
pyroman131, your rims are great too. What is the size on your rims? 18X? Also, what offset they have?
xseveredveganx, by running larger diameter tires, you get higher speed at the same rpm. You are right, it will increase the gas mileage on accelerations, but I think at cruising speed it will decrease the gas mileage as the engine will run at a lower rpm. However, the mpg is not my highest concern. If there is anything that xB gen 2 with manual trans is crying for, it is the 6th gear.
Old Jan 22, 2014 | 06:10 AM
Info on the specs 19x8.5 +38 offset concept one USA rims . 225/35/19 falkens . 10mm spacer in the rears . NF 210 springs , rides great however I'd like it a bit lower .
Old Jan 22, 2014 | 03:37 PM
pyroman131's Avatar
REDACTED
Old Jan 28, 2014 | 02:40 PM
pyroman131's Avatar
REDACTED
Old Jan 28, 2014 | 10:48 PM
Utah Scions
Originally Posted by pyroman131
And this is where CIONIDE is supposed to drop in and help us out...
Meh. The info is here, people just have to look for it.
12thhawksfan
Jul 14, 2015 06:18 AM
posiden
Mar 22, 2015 03:03 AM
Maroonls1z
Scion tC 1G Wheel & Tire
Jan 14, 2015 01:15 PM
kleecker
Scion xB 2nd-Gen Wheel & Tire
12
Dec 31, 2014 04:07 PM
kleecker
Dec 31, 2014 09:42 AM
