Buying 2012 Scion xB...19x8.0 30 0ffset work?
Old Sep 7, 2011 | 08:51 PM
a808angel's Avatar
Default Buying 2012 Scion xB...19x8.0 30 0ffset work?
Hi Guys...gals, have my xB on order and just wanted to know if these Konig Heatsinks would work on my new ride... 19" KONIG HEATSINK WHEELS 19x8 5x114.3 SET OF (4) RIMS | eBay
It's the right bolt pattern, just need to know if the 30 offset will work...cant wait for my Scion...i have ordered the trd springs also, so that may be a factor also, i just want them to not stick out the wheel well...
19" KONIG HEATSINK WHEELS 19x8 5x114.3 SET OF (4) RIMS /30 offset
Aloha and Mahalo!
Old Sep 7, 2011 | 10:23 PM
xseveredveganx's Avatar
Utah Scions
Depends on the tire size. But for the most part, yes. They'll fit.
Old Sep 7, 2011 | 11:31 PM
a808angel's Avatar
Ok, cool? In this forum somewhere there was white sion 2008 I think that had this wheel, 19x8.0...not sure if the off set was 40 instead of 30...konig made a few different off sets for this wheel... I can't seem to escape the look of this wheel...love em!
Old Sep 7, 2011 | 11:53 PM
EGG80x's Avatar
the rear will fit with no problem, you can run 225 or 235 width
but for the front, its best to go 215 or 225 width
Old Sep 8, 2011 | 12:31 AM
Ricersux's Avatar
Im running a 20x8.5 +35 and it fits so you are ok.
Old Sep 8, 2011 | 12:36 AM
a808angel's Avatar
225 all the way around would be a good idea than huh?, and these will not make contact with frame as you turn, or rub on any brake components or require a roll of the fenders, i may just stay stock for awhile, and put the TRD drop springs on later....it's part of the accessories that i have bought with the scion XB. here is the XB... https://www.scionlife.com/forums/sho...d.php?t=108595
like the machined lip....any other wheels u guys know of with this similar look?
Old Sep 8, 2011 | 01:10 AM
Utah Scions
OEM TRD wheels are 19x8 +48mm with 235/35R19's. I'd assume that anything similar in specs, should be fine. I'm on the TRD wheels with the 235/35R19's and coilovers. I rub a little on the inside of the front while turning full-lock. Otherwise, no rubbing. Just fender liners.
Old Sep 8, 2011 | 01:39 AM
CIONIDE's Avatar
Don't wait to put the TRD springs on. That pic you linked to of the Heatsinks on the white xB look way HOOPTIE all jacked up on the OEM springs.
19x8 +30 will basically be dead flush up front, and tuck about 1/2" in the rear. On TRD springs you should be OK with 225/35-19 tires.
Tire size & drop would also be helpful... air ride?
Old Sep 8, 2011 | 03:29 AM
Shadezz's Avatar
I have the Konig Unkowns 19x8 w/ 38 offset 235/35/19 and no rub, but wait no drop yet either. Go for it!! Another Konig Wheel Owner!!
The only thing I don't like about your choice....The fact that it has multi-bolt pattern...
Old Sep 8, 2011 | 03:34 AM
Shadezz's Avatar
A few for the Konig lovers....
Old Sep 8, 2011 | 04:14 AM
vancouverray's Avatar
Go with the Tanabee NF 210 , my ride is way better than stock . 19.8 +38 with 225 35 and no rubbing at all . Just get Cionide to guide you ..................
Old Sep 8, 2011 | 04:55 AM
a808angel's Avatar
Red face
So this looks like the holy grail of all things Scion, really excited about my new scion...white at that, so the tire I wanted to put was a 40 series tire...wanted some protection on the lip and side wall, but if it's not possible...I guess 35's will do, I'm putting the springs from the sion accessories add on site (the one that you can add to the purchase price...you know, the build your scion xb site) I think It's 1.5" front and back...need to see if it is going to rub on turns...I really pray they don't rub....
Old Sep 8, 2011 | 02:56 PM
CIONIDE's Avatar
TRD springs drop it 1.0" front & 1.5" rear. 19x8 +30 will rub with a 40 series tire. Stick with the 225/35.
Old Sep 8, 2011 | 08:44 PM
a808angel's Avatar
V
Just wondering what the off set of your wheel's are...
Old Sep 9, 2011 | 04:34 AM
CIONIDE's Avatar
Gotta read the whole thread...
Old Sep 9, 2011 | 05:57 AM
Shadezz's Avatar
It's funny when its right there in front of you.
Old Sep 9, 2011 | 11:37 AM
a808angel's Avatar
my apologies... did not see that, by the way....nice ride.
Old Sep 9, 2011 | 12:45 PM
Shadezz's Avatar
No worries I've been blind a time or two myself....
Old Sep 24, 2011 | 12:52 AM
a808angel's Avatar
Thanks again guys for the feed back, since i am not gonna find a set of 18x8.0 Konig Heatsinks, they are discontinued everywhere, i have narrowed down my choice to the TSW Willow's http://lsdmotorsports.com/ctgy/901124044.html ... I will be buying the 18"x8.0 5x114 i think with the 1.5" machined lip all the way around will look nice, but... my question is if i can get the 3" Machined lip wheels for the back 18x9.5, and should i get the +40 off set for the rear...with what size tire...whew! Cionide, thanks for the 2 cents on how Jacked! the Heatsinks looked on that white XB, made me not want 19" (too much drop i felt to make em tuk right, dont want to put too low a spring on my XB) Loved the Konig but i am starting to Love these too...hope they look nice on my 2012!
Old Sep 24, 2011 | 01:07 AM
Utah Scions
You could possibly run a 225/40R18 all the way around with the 18x8 and 18x9.5 staggered setup. However, you may have to roll the fenders a little in the rear so you don't chew tires.
