Do you have to have a dealership reset the tire monitoring light for rotating ?!?!? - Scionlife.com
Scion xB 2nd-Gen Wheel & Tire
Wheels and tire combinations...
Click Here
Reply
Thread Tools Search this Thread
Old 04-19-2017, 10:33 AM   #1
Default Do you have to have a dealership reset the tire monitoring light for rotating ?!?!?
Got a new set of tires put on my 2012 XB. I am sure the wheels (stock) didnt get put back in the same spot and now my TPMS light is on. Called the dealership.and they said they are programmed for the wheel they are on and they will reset them for an hour labor!!
Doea that mean toyota has this set up so they need reprogrammed every time.you rotate your tires!! If so thats a bunch of crap. Is there a way i can do this otherwise? The reset button by the column does nothing
Natejones75 is offline   Reply With Quote
Old 04-19-2017, 08:10 PM   #2
Greg S's Avatar
No, the ecu doesn't care where they are on the car. Check your pressures to make sure you do not have one tire low. If you don't, then try reseting them. There is a small button under the dash on the right side of the steering column that you press and hold for 10 secs with the ignition on to reset them. If this fails then you can take it to most major tire shops and they can relearn the sensors to the car. You don't have to take it to the dealer for learning them to the car. It is possible that one of the sensor failed or was damage when the new tires were put on so you might need a new sensor.
Greg S is offline   Reply With Quote
Old 04-20-2017, 07:22 PM   #3
SquallLHeart's Avatar
newer cars have the sensors built into the wheel. check your pressures first.
SquallLHeart is offline   Reply With Quote
Old 05-02-2017, 09:40 PM   #4
XBroker's Avatar
Guess you know what dealership to avoid?
XBroker is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
