need tire advice
I purchased some 17X8" +35 all around I am dropped on hotchkis coils I wanted to see if I could run some 215/45R17's without any issues I want to buy the tire either today or tomorrow any help would be great. I have searched around and could not find anything on this particular set up.
You'll be stretching that tire. Is that what you're wanting to do?
I just want them to fit with no rubbing
My winters are 215/40Rx18" with +35 on full TRD without rubbing on my '11 xb
@TheotherBman I purchased the 215/45R17 Everything points in the direction that it should work, I was hoping some one here had a similar set up but really didn't get a solid answer I will put them on and see what happens. thanks for your insight it kinda confirms that these tires should work.
Basically, they are the same dimensions as far as fit https://www.tacomaworld.com/tirecalc...0r18-215-45r17
That's a good tool I was using this one Rim & Tire Size Calculator. Custom Offsets - Wheel-Size.com
lets you change stuff around like fender and wheel well. |
