How to Remove Window switch bezel/cover
I have a 2008 xD.
I've read that to remove the window switch switch bezel/cover I need to slide a screwdriver under the front of the bezel in order to release the clip.
I don't seem to be doing that correctly, though, because the bezel won't release.
I've been looking for a photo or drawing of the underside of the bezel so that I can better aim the screwdriver, but I haven't found such a photo/drawing so far.
If anyone can provide a URL to such a drawing or Vid, I would be most grateful.
Thanks in advance for any help.
Last edited by MR_LUV; 02-12-2018 at 02:56 AM. Reason: Insert Moderator's Note tip
Administrator
Administrator
I've read that to remove the window switch switch bezel/cover I need to slide a screwdriver under the front of the bezel in order to release the clip. I don't seem to be doing that correctly, though, because the bezel won't release. I've been looking for a photo or drawing of the underside of the bezel so that I can better aim the screwdriver, but I haven't found such a photo/drawing so far. If anyone can provide a URL to such a drawing or vid, I would be most grateful. Thanks in advance for any help.
Sticky What does Garage is empty, Add now mean?
◄◄Click Here under your User ID
Moderator
FYI, You Increase your Chance of a Reply if you were to Identify your Model Year.
Moderator
Moderator
I added model year to my post.
Administrator
Administrator
99-03 Lexus Rx300 Driver's Door Panel & Window Switch Removal YouTube video
Go to 3:00
The Official Toyota Parts List show only a small drawing of the part w/o the underside. It appears there is a release clip towards the forward area.
There are no 2008 xD Switch Cover Removal video unless you want to Create your own. Refer to the Lexus Rx300 video as a hint/tip.
It is Highly Recommended that you Do Not use a screwdriver as a pry tool (common rookie mistake). It will scratch the surfaces and may also result
in breaking your tabs therefore compounding your problems.
Do as the Pros. Get a Professional Set, which are inexpensive similar to these:
Hope this helps.
MR_LUV
sciontcnj
12-07-2007 02:34 AM
NewMexicoxBPhatBoy
09-14-2006 02:22 PM
