Problem with Radio Clock Keyless entry
Ok so I put my CAI on pulled my radio out hooked everything up and the radio doesnt work on the center waterfall where the time pops up doesnt show the time it just lights up and my keyless entry doesnt work. I checked wires an I reconnected everything does anyone have any ideas wtf is wrong Im guessing its a fuse but It happen late last night an I wasent in the mood to check an Im in work now >.<
Check your fuse and check if everything is firmly connection on the back of the waterfall and on the back of the radio. Do you have the stock HU or aftermarket? If aftermarket, check the fuse on the back of the radio. If stock, check the fuse under the dash.
Sounds like you inadvertently got the clock and radio plugs mixed up. One of the radio plugs fits the clock and vice versa, and it takes out the fuse when you mess up on the insertions. make SURE the wires are plugged into the right socket, and after you replace the blown fuse, you'll be all good again......
There were some pictures of the radio and it's plugs in the back on this forum before, but I'm not sure where they are now located. Things have changed and the old links are no longer usable.
Good Luck!
Good Luck!
