Scion xD ICE & Interior In-car entertainment and electronics...
How to Remove Window switch bezel/cover
Old 02-06-2018, 06:00 PM
scion_boyo's Avatar
Default How to Remove Window switch bezel/cover
I have a 2008 xD.
I've read that to remove the window switch switch bezel/cover I need to slide a screwdriver under the front of the bezel in order to release the clip.
I don't seem to be doing that correctly, though, because the bezel won't release.
I've been looking for a photo or drawing of the underside of the bezel so that I can better aim the screwdriver, but I haven't found such a photo/drawing so far.
If anyone can provide a URL to such a drawing or Vid, I would be most grateful.
Thanks in advance for any help.
Last edited by MR_LUV; 02-12-2018 at 02:56 AM. Reason: Insert Moderator's Note tip
scion_boyo is offline
Old 02-06-2018, 08:30 PM
Administrator
Administrator
MR_LUV's Avatar
Originally Posted by scion_boyo
I've read that to remove the window switch switch bezel/cover I need to slide a screwdriver under the front of the bezel in order to release the clip. I don't seem to be doing that correctly, though, because the bezel won't release. I've been looking for a photo or drawing of the underside of the bezel so that I can better aim the screwdriver, but I haven't found such a photo/drawing so far. If anyone can provide a URL to such a drawing or vid, I would be most grateful. Thanks in advance for any help.
FYI, You Increase your Chance of a Reply if you were to Identify your Model Year.
Sticky What does Garage is empty, Add now mean?
Click Here under your User ID
Moderator
MR_LUV is offline
Old 02-06-2018, 09:05 PM
scion_boyo's Avatar
Moderator
Good point. Thanks.
I added model year to my post.
Old 02-06-2018, 09:29 PM
Administrator
Administrator
MR_LUV's Avatar
99-03 Lexus Rx300 Driver's Door Panel & Window Switch Removal YouTube video
Go to 3:00
The Official Toyota Parts List show only a small drawing of the part w/o the underside. It appears there is a release clip towards the forward area.
There are no 2008 xD Switch Cover Removal video unless you want to Create your own. Refer to the Lexus Rx300 video as a hint/tip.
It is Highly Recommended that you Do Not use a screwdriver as a pry tool (common rookie mistake). It will scratch the surfaces and may also result
in breaking your tabs therefore compounding your problems.
Do as the Pros. Get a Professional Set, which are inexpensive similar to these:
Amazon Amazon
Hope this helps.
MR_LUV
MR_LUV is offline
Old 02-06-2018, 10:05 PM
scion_boyo's Avatar
Smile
My goodness, Mr Luv, that is totally awesome! I now have that part lifted up.
Thank you, Muchas Gracias, Vielen Dank!
flyguy327
Scion tC 1G Aero & Exterior
12-11-2010 03:04 AM
sciontcnj
12-07-2007 02:34 AM
NewMexicoxBPhatBoy
09-14-2006 02:22 PM
HKSpeed
09-24-2005 08:10 AM
05polarxb
04-15-2005 11:27 PM
Quick Reply: How to Remove Window switch bezel/cover
