Scionlife.com
Scionlife.com (https://www.scionlife.com/forums/)
-   Scion xD Owner's Lounge (https://www.scionlife.com/forums/scion-xd-owners-lounge-1769/)
-   -   ABS/BRAKE light randomly on 08’ xD (https://www.scionlife.com/forums/scion-xd-owners-lounge-1769/abs-brake-light-randomly-08%92-xd-282504/)
Mrkline88 Feb 7, 2025 11:12 PM
So for the last couple months (2-3) one of the tire lights would just stay on randomly. It finally went off (would come back intermittently) then finally fully off couple days ago.
Then today the ABS/BRAKE light showed up. No issues stopping nothing seems or feels different.
kinda reading people have these issues? But wanted to double check. Is it something I should be worried about?
MileHightC Feb 8, 2025 02:36 PM
Nahhhhh, why would you even be remotely concerned about a warning light for your brakes coming on?
Yes, you should want to figure out what is causing your Brake/ABS light to come on, I cannot imagine the manufacturers are adding warning lights for things just to randomly annoy people. Have you even started looking into what could have cause the tire or Brake/ABS lights to come on, there's likely a wealth of information on here outside of, "Well, I noticed other people had those lights come on also..."
Mrkline88 Feb 9, 2025 01:42 AM
yes from everything I’m reading the sensor is sketchy. That the sensor and where it’s positioned goes bad. And yes I had it checked out and they didn’t see or notice anything of concern so most likely the sensor is messing up either corroded, or winter/salt messing with it. And as I said it goes off and off randomly and brakes are fine, lines are fine fluid is fine. So assume it’s the sensor in which connects to the hub and if I don’t have to replace I’d rather not.
© 2026 MH Sub I, LLC dba Internet Brands
