OFFICIAL: Tanabe Sustec Strut Tower Bar 2008 Scion XD
Which would also introduce the ability to flex, since there's only two attaching points, not three. It's like taking a tripod and trying to shake the top back and forth, then taking a stick and doing the same thing. The stick is obviously going to move a lot more. Let's see what they have to remedy this problem, I won't be the first one to buy. They would have to have a brace, essentially making it a triangle, but one that is in-line with the brace. Hard to explain, so here's a quick drawing:
i also dont like the fact that there are 'hinges' between the bar and the mounting plates. now that i think about it, that seems like it would render the bar entirely useless. ive seen many other strut bars that do not have this at all, and im not sure why companies put these flex points in a strut bar meant to control flexing.
i may be holding off now...
hmm... id really have to see one of these installed, as im not really sure how it would mount up on the xD...
has anyone purchased this yet? i really dont want to be the guinea pig on this, my to-do list is long enough as it is, lol.
Re: OFFICIAL: Tanabe Sustec Strut Tower Bar 2008 Scion XD
Can't see how this would help anything - the bar is right next to a structural element which would have the same effect as the bar. The xD doesn't need (or want) a front bar.
Thats why TRD doesn't sell their version of this bar because it is so tightly packed in the engine bay it doesn't make sense to even have that bar. PLUS the TRD, and Tanabe, was found to block access to the battery so thats another reason why you probably won't see it or see it very little on the market.
I am having the Dealership install this strut brace and they called and indicated it is right over the negative post on the battery. I contacted Tanabe corporate and they indicated that the bar would have to be removed to replace the battery. Totally agree with recent posts there is little room for a strut bar witout impeading something under the hood. I'm still going to have the bar installed.
Absolutely worthless.
Sorry to be so blunt, but you will see no difference after install. The bar doesn't have a purpose on this car. The engine compartment is already so tight and boxed, that the bar only adds weight. Buy it for aesthetics, but know - deep down - that it does nothing for cornering / handling.
On other cars maybe - on this car - nothing...
You are right, I can't tell the difference at all because it was a new car with the optional TRD Sport Struts installed. So I have nothing to compare it too. I didn't know and it is too late now.
After it has been installed the Dealer Service Manager stated that the design of the bar is good because there is a single nut/bolt connector at the bar linkage to the housing when a battery needs to be changed. Simple need to remove them from both sides rather than removing the strut bolts.
