Scion xD Suspension & Handling Coilovers, Shocks, Airbags, Swaybars...
Rear TRD lowering spring install question - which way does the coils face?
Old 06-26-2010, 07:13 PM
ramrat's Avatar
Default Rear TRD lowering spring install question - which way does the coils face?
in the TRD manual it states
"Position the tightly wound coils facing the beam axle spring seat."
I would assume that the tightly wound coils is down and the other part is not.
When I looked at scion parts people picture it had it opposite what i think the instructions are saying.
Does anyone know know if the tightly wound coils should be installed facing down towards the ground or up towards the car?
ramrat is offline
Old 06-27-2010, 02:51 AM
DTC08's Avatar
dont look at the instructions just take it out, inspect how everything is BEFORE you take it apart and then installing is the exact opposite. you will be able to tell once u put em on how it goes... its very simple
DTC08 is offline
Old 06-27-2010, 04:29 AM
ramrat's Avatar
hmm that doesn't help as the TRD spring and the Stock spring are different.
TRD srping has one side of the coils thats tightly wound and I am wondering if the tightly wound portion goes on the bottom or on the top spring seat.
Scion Parts web site shows it on the top while I believe the instructions say to put it on the bottom...
ramrat is offline
Old 06-27-2010, 04:37 AM
ramrat's Avatar
I found a picture of the underneath of a xd with trd's and they had theirs installed with the tightly wound coils on the bottom. So the scion parts web site has their spring installed incorrectly...
ramrat is offline
Old 07-24-2010, 03:22 AM
two.0XD's Avatar
Exclamation
I just got my sway bar,and my XD is 09, but the box and instruction say for 06-08...should i be worried?
two.0XD is offline
Old 07-24-2010, 04:17 AM
ramrat's Avatar
xd started in 08 so i assume you got the Yaris sway bar but I believe their one and the same (sway bars). others will chime in and will be able to tell you for sure.
ramrat is offline
DJ_FroZone
25
05-30-2019 07:17 PM
torranosaurus
01-28-2015 04:53 AM
lunchbx05
12-29-2014 07:53 PM
Scionxa180
16
12-08-2014 04:00 PM
rolex87
10-13-2003 05:48 AM
Quick Reply: Rear TRD lowering spring install question - which way does the coils face?
