Wheel offset?
I'm looking for a set of used aluminum wheels in 16"Ø. Aside from a few Corollas and Yarii, nobody else uses the exact same size wheel. However, some old Subarus did have 5x100 bolt circle Ø, 56.1mm center hole, but their offset is 48mm.
The xD's that came with aluminum wheels (6.5" width) had 45mm offset, and my stock steelies (6" width) have 39mm offset. Will I have any issues putting that Subaru wheelset on? Will there be clearance issues?
Will the extra negative scrub radius be an issue? Will I need new lugnuts?
________
________
I'm looking for a set of used aluminum wheels in 16"Ø. Aside from a few Corollas and Yarii, nobody else uses the exact same size wheel. However, some old Subarus did have 5x100 bolt circle Ø, 56.1mm center hole, but their offset is 48mm. The xD's that came with aluminum wheels (6.5" width) had 45mm offset, and my stock steelies (6" width) have 39mm offset. Will I have any issues putting that Subaru wheelset on? Will there be clearance issues? Will the extra negative scrub radius be an issue? Will I need new lugnuts?
Thanks.
__________
Yes, but I got a set of anodized lugnuts with a 60° bevel, and a 5mm spacer for each wheel, which gives me a 43mm offset. The xD requires 100mm BCØ, and only a few Subarus have that; many have the same 112.5mm BCØ that a Camry has.
____________
____________
buzzdogear777
Scion tC 1G Wheel & Tire
Jul 16, 2009 05:59 PM
ninja929
Scion xB 2nd-Gen Wheel & Tire
Oct 19, 2008 07:53 PM
