SOLD
Old Feb 13, 2011 | 03:38 AM
cbridges17's Avatar
Default SOLD
Hey guys. I just bought these from dqlostsoulz. They are 15mm bolt on spacers just like the ichiba version II. They are hubcentric for the tC1. 5x100.
Reason why i bought these was for the rims i had up until today. Reason why I'm selling is I just sold those rims to pick up a more aggressive pair I came across and do not need these spacers anymore.
Here are some pics from
dqlostsoulz. I did not install them. I've had them for maybe 4 or 5 days and counting.
*They are missing 5 nuts. I bought them this way, the other nuts were stripped. So there are 5 nuts in decent shape and the other 5 are in the garbage.*
PM me if you are interested. Thanks for looking! $60 shipped obo. $50 picked up in CT. I will also entertain trades. Let me know what you have. If you are local I'm looking for 18" tires <- and on my end I would add money onto the spacers for tires.
Old Feb 13, 2011 | 04:47 AM
Tom11x's Avatar
I need these
Old Feb 13, 2011 | 09:06 PM
cbridges17's Avatar
pm'd
Old Feb 13, 2011 | 09:27 PM
2006steezypurps's Avatar
yo bridges do these look good with stock wheelS?
Old Feb 13, 2011 | 09:44 PM
cbridges17's Avatar
dont know. i havnt installed them. im sure they do. 15mm on the rears would probably look pretty nice.
Old Feb 14, 2011 | 05:59 AM
cbridges17's Avatar
pictures added.
Old Feb 15, 2011 | 02:23 PM
cbridges17's Avatar
bump
Old Feb 15, 2011 | 03:09 PM
Dam262a's Avatar
so u threw away the bolts or the nuts?
Old Feb 15, 2011 | 04:57 PM
cbridges17's Avatar
i didnt. i bought them with only 5 nuts. the other 5 were stripped and didnt work. so these need 5 more. i talked to ichiba and you can order new nuts from them, you just have to call them.
Old Feb 15, 2011 | 05:02 PM
Dam262a's Avatar
how do u replace the bolts arent they within the spacer?
Old Feb 15, 2011 | 05:28 PM
cbridges17's Avatar
idk if you understand how these work. the studs are what you see sticking out. all of those are fine. the spacers slip onto your hub and then you use the nuts you see to connect them to your hub. then you put you wheel onto the studs attached to the spacer and you use regular lugs to attach your wheel.....
all you need is 5 more nuts for the other spacer because the original nuts stripped, the studs are fine.
Old Feb 15, 2011 | 05:57 PM
Dam262a's Avatar
no i dont think u understand, ur mixing bolts and nuts, they're different a nut goes onto a bolt,
Studs=bolts
lugs=nuts.. hence lug nuts
u finally made it right on the post above
confusion:
i didnt. i bought them with only 5 nuts. the other 5 were stripped and didnt work. so these need 5 more. i talked to ichiba and you can order new bolts from them, you just have to call them.
Old Feb 15, 2011 | 06:06 PM
cbridges17's Avatar
alright man, i thought it would have been clear based on the pictures because all of the studs are clearly there, and that 5 nuts are clearly not there.
my fault though. i edited my original post to make it more clear.
Old Feb 16, 2011 | 05:35 PM
cbridges17's Avatar
bump
Old Feb 17, 2011 | 06:04 PM
cbridges17's Avatar
up. pm me offers. don't need these anymore.
Old Feb 18, 2011 | 12:56 AM
CSOCSO's Avatar
im interested......
Old Feb 18, 2011 | 06:04 PM
cbridges17's Avatar
pm sent ^
Old Feb 20, 2011 | 02:16 AM
cbridges17's Avatar
SOLD
rain7905643
Jun 13, 2018 05:29 AM
Luna7ic
Sep 28, 2015 03:30 PM
MisterSkiz
Sep 27, 2015 10:25 PM
jdmautoimports
Regional - Canada
Sep 24, 2015 04:00 AM
