Scion tC 2G ICE & Interior In-car entertainment and electronics...
Air leak around driver's window glass???
Old Feb 18, 2012 | 03:41 AM
Patriot07's Avatar
Default Air leak around driver's window glass???
I've been noticing a slight but annoying loose seal/air leak when driving on my tC2. It's on the upper rear corner of the window/door, and I can't seem to isolate exactly where it is coming from. Only happens above about 30 mph. I actually had the dealer replace the window glass track seal, but the noise is still there. Could this be the main seal around the door - or possibly even the glass itself? Any ideas? I don't want to have to by process of elimination have the dealer replace all these parts.
Old Feb 18, 2012 | 06:30 AM
STlTCHES's Avatar
use tape around the window tape the whole weather stripping up with painters tape and take it off bit by bit till you find the noise again.. thats your problem
Old Feb 18, 2012 | 12:50 PM
Patriot07's Avatar
Default Good idea...
Stitches -
Just to clarify - are you saying to put the painter's tape around the outside of the glass - not the door seal - then take small pieces of it off in sections, replacing it if I don't hear the noise - until I isolate it? At least that will tell me if it's the actual window seal and not the door seal itself -
Old Feb 18, 2012 | 01:14 PM
STlTCHES's Avatar
Yeah thats what I meant. Sorry I ramble alot.
But yes that should isolate your air leak down to an area then its figuring out if its weather stripping, door seal or glass (im betting its the door seal)
Old Feb 18, 2012 | 01:54 PM
ProjectTC2's Avatar
I have the same exact problem in the same exact area of my drivers door I don't even know where to start to fix it
Old Feb 19, 2012 | 04:19 PM
Druidiron's Avatar
X2, only recenlty have I noticed it too.
Old Feb 19, 2012 | 05:27 PM
VVTinme's Avatar
I have a feeling they all do this. My tC does it too; the rubber seal was replaced around the driver's window which helped, but only marginally. It hasn't bothered me enough to do anything about it since it's never been more than the slightest annoyance. I don't even notice it anymore.
Old Feb 19, 2012 | 06:14 PM
GAPS11TC's Avatar
I dont have that problem, sucks for you guys! LMAO! jkjk i think i'm starting to realize the same problem
Old Feb 20, 2012 | 05:34 PM
Errikos's Avatar
hmm ill have to listen later on my drive home, never noticed it before
if you go to the dealer most likely response will be oh don't worry that's normal
Old Feb 23, 2012 | 03:43 PM
Patriot07's Avatar
Default Reporting this problem to dealer...
Has anyone other than me reported this issue to your dealer? They will submit a formal service bulletin on it if they get enough feedback. I would definitely contact your dealer and send them a link to this particular thread showing them that others are experiencing the same problem - and it is not isolated to only a few cars.
Only by bringing this to the dealers' attention will anything be done about it.
Please notify your service manager about the problem.
Old Mar 3, 2012 | 09:57 PM
devanb3's Avatar
i know i had a similar problem in my 11 but it was a pressure release hole in the door seal in the corner its put there to allow pressure in/out so your car doesnt "pop" everytime you open the door
Old Aug 3, 2012 | 04:07 AM
Patriot07's Avatar
Default Noise is still not completely gone...
I had the dealer replace the plastic corner trim piece on the inside of the door which contacts the rubber door seal, but I still hear the vibration of that plastic piece it seems - against the rubber seal. If I put a piece of blue painter's masking tape over the plastic corner piece on the door, that seems to stop the noise completely. Wondering if this is simply a case of the rubber not sealing quite tight enough against the door in that area. I'm afraid to have the dealer replace that seal around the entire door opening - looks like a big deal that they could really screw up. Any thoughts?
SuperXero
Scion tC 1G ICE & Interior
Feb 23, 2020 08:17 AM
idriveanxa
Mar 8, 2015 12:03 PM
CPL_Radar
Mar 5, 2015 05:42 AM
toyotaisme
Jan 10, 2015 10:24 PM
minter66
Dec 15, 2014 01:45 PM
