Fuel problem
Old 01-02-2017, 05:29 PM
Sgtusmc98's Avatar
Default Fuel problem
Hello to everyone, I looked but couldn't find a situation like this. A few months ago my 2004 xA stopped taking fuel, the previous time I filled up it would take it at the pump as fast as the pump then one day
I tried to fill up and couldn't get any gas to go in the tank, thought it may be the pump so I went to other stations and same problem. When I got home I was able to put gas in with a gas can.
Assuming the vent lines were clogged I disconnected both lines near the tank and forced air through them in both directions with an air compressor. I did here stuff come out into the tank (could have been a sensor for all I know).
Blowing the lines did help me get fuel in, now I can go to the pump but it's not as good as it once was. However when I fill up for a while the car has sporadic power loss as if the filter was clogged for 10-20 miles.
I was going to replace the fuel filter but saw on here that it rarely needed changing and was in the tank. I also seem to have gone from 37 mpg to 32 mpg.
My guess if still fuel filter but I may have broken something blowing air through the fuel tank vent lines too.
Ideas would be appreciated!
Last edited by MR_LUV; 10-02-2018 at 06:59 PM. Reason: Moved to Correct Forum by Administrator
Sgtusmc98 is offline
Old 01-03-2017, 12:05 AM
jct
jct's Avatar
you charcoal canister needs to be replaced
i went through the same head ache as you are
Duralast Vapor Canister VC4083 - Read Reviews on Duralast #VC4083
jct is offline
Old 01-03-2017, 01:07 AM
Sgtusmc98's Avatar
Jct thank you! I'll pick up one of those and see if that fixes it!
Old 01-11-2017, 09:39 PM
jct
jct's Avatar
did that fix your issue?
jct is offline
Old 01-12-2017, 06:44 PM
Sgtusmc98's Avatar
Unfortunately my car is not the only thing broken, I haven't gotten to it yet. I'll try and let you know when I do. I do have to work on stuff outside so if the weather is frightful I'm slow!
Old 01-13-2017, 02:23 AM
jct
jct's Avatar
i hear you there, i'm in the same boat
jct is offline
Old 09-23-2018, 03:43 AM
Sgtusmc98's Avatar
sometimes it takes me a while to get to things, I replaced the charcoal canister about a month ago but haven’t really driven it. I fixed it because I lost a lot of power getting home one day. After putting the new canister in I discovered the alternator had locked up and broke the belt. That was a disaster to fix because of corrosion and a couple of bad alternators. Tomorrow I will try to drive it, hopefully it will work! Sorry for the long delay but I just got to it!
ArielTheScionTC
10-31-2018 04:01 PM
Zoots
09-04-2012 03:11 PM
kragmaul
09-04-2008 06:46 PM
rebelMan
12
08-01-2006 09:29 PM
tvc15_2000
15
02-28-2006 12:09 AM
Quick Reply: Fuel problem
