Energy Suspension Control Arm Kit
Old 04-18-2017, 11:58 PM
Stiffology's Avatar
Default Energy Suspension Control Arm Kit
Question for anyone who has installed one of Energy's poly bushing kits on your control arms. I burned out my control arm rear bushing to salvage the "oval sleeve" but only came out with a basic regular one.
Am I able to use it like that or does anyone know where to get one of those by itself or a bushing that contains one.
Instruction manual I got:
http://imagesrv.catalograck.com/imgVD/ENE/17441.pdf
Pic of what they should look like?
Sleeve I got out of my Control Arm
Took a chance and got an 07 Corolla Front C-Arm rear bushing, burned it out and got this...
Any help appreciated. This is the 8.3120R kit that is part of the master kit purchased for my 2010 tC.
Stiffology is offline
Old 04-19-2017, 09:37 PM
Stiffology's Avatar
Afternoo Scionlife, for all those who come across this same issue don't worry... I've solved it myself. The "oval sleeve" required is only found in our OEM Toyota control arms (Inner-rearward main bushing).
These cannot be found in any aftermarket Dorman, Mevotech, or other brand C-arms.
Like this below:
2010 tC Front Right: 48068-21020
2010 tC Front Left: 48069-21020
Thanks for viewing and hope this helps anyone.
Old 04-20-2017, 12:13 PM
bbsciontc's Avatar
Thanks for posting this. That was my suspicion, but I don't have any way to check it. The aftermarket uses generic parts to keep costs down, so I'm not surprised. Glad you figured it out and shared it with everyone.
bbsciontc is offline
Old 10-17-2017, 08:05 PM
Ricenbeans's Avatar
Great info thank for sharing, how did it improve the ride and handling ?
Ricenbeans is offline
Old 10-22-2017, 02:12 PM
Stiffology's Avatar
Stiffer more presise handling even when coupled with soft springs or shocks, expect ride comfort to decrease. Braking is more presice, less nose dive. I have been using the whole bushing kit installed for a good 6000 miles and have no issues/noises.
Old 10-22-2017, 03:27 PM
Ricenbeans's Avatar
Nice thanks for the info, I'm going with the bushings and Tein
Street coil overs
Old 06-07-2022, 02:42 PM
sumday's Avatar
when looking through the inside of the bushing if its completely straight then its aftermarket. oem will be oversized inside to match the bulge outside
sumday is offline
