AXCP-Q14U (T10015) OEM Radio work with a 2009 xB?
Hello,
I'm wondering if a AXCP-Q14U (T10015) OEM Radio will work with a 2009 xB?
____
____
Yes, it works properly in my 2009 xB.
My setup is:
* T10015 head unit with harness/wires ($200 on craigslist; you must get both wires or you'll have to buy them separately for a lot of $)
* PT296-00142 bespoke navigation modules ($175 on eBay)
* PT546-74120MC bluetooth microphone ($58 on eBay)
* 16 pin toyota backup camera adapter and eBay backup camera (about $50 combined)
* PAC line-out converter for subwoofer amp ($12 on amazon)
This gives me all features including navigation, backup camera, Bluetooth voice control, etc., and it integrates perfectly with my IS250 steering wheel without any adapters.
On the topic of forum activity, the xB scene has really died down. You're got this site, NewscionxB, and Clubxb if you want somewhere active. Some of the others (Scikotics and such) are pretty much dead.
____
Ok. I went ahead with the T10015. Can this plug right into my xB without the extra stuff at first.
Until I get enough $$ for the rest? Which wire harness are you referring to?
____
____
Yes, provided you have the cables required for it (this is two separate harnesses):
Make sure you get those with the radio; I believe they are rather expensive to buy separately.
Note that the Bluetooth voice commands and calling will not work without a microphone installed.
____
_____
I think this is the other:
The best prices I see are:
PT546-00120-AD 21.94 on eBay
PT546-00120-CH 30.80 on Amazon
____
____
Thanks man! I'm gonna order the other two today.
I cant find the navigation module that you listed.
I hope I run into one though!
____
____
The navigation module is hit and miss.
Bad:
* The actual navigation is, like pretty much all factory navigation setups, really stupid. Your phone will do a much, much better job.
* Bluetooth connectivity is very slow to load; expect 20-40 seconds each time you get in the car.
Good:
* The module doesn't just add nav; it replaces a lot of the menus. Bluetooth audio has a much better menu with better controls, album art, etc.,
and the phone menus and options are awesome.
* Having OEM Scion Navigation increases the value of your car (which is rare since most modifications do the opposite)
____
Bad:
Good:
____
The two compatible models are (you just need one of them):
PT296-00142-AA
PT296-00140-AA
You'll see them listed without the -AA sometimes. I'm told that 00140 has older maps than 00142, but the navigation is pretty cheesy as it is, so I would just get whatever is cheap.
There are two items you absolutely must get with it:
* GPS antenna
* Cable (connects it to your existing head unit)
It's also good to get the mounting brackets (PT591-00140) but you can make some yourself out of thin metal or plastic and a drill bit if needed.
____
PT296-00142-AA
PT296-00140-AA
* GPS antenna
____
Yes; here's a pretty good quality unit for $10.49 that will let you hook up an amplifier for a sub:
____
____
I got the Head Unit all hooked up and it is working. I just need to get the Bluetooth mic and maybe run into the Nav module :/
Oh, one more thing. I noticed that on the wiring harness there are one plug that is empty it's square and then
Another plug that was on the stock HU that doesn't have a place to connect on the new HU.
Sorry for my vague explanation, I just don't know what it's called!
___
___
Update
Wondering if anyone here has current links to what i would need to get full functionality with swapping an AXCP-Q14U(part# PT296-00142)
for the 2009 xB original head unit (part# PT546-00080). there is no good information available on if it's even possible besides this thread basically.
___
___
