OCV Oil Control Valve (VVT Solenoid) and Filter Question
Old 07-19-2017, 06:03 PM
05xboxer's Avatar
Default OCV Oil Control Valve (VVT Solenoid) and Filter Question
1. Have an 05 Scion xB. I removed the Oil Control Valve (sometimes called the Variable Valve Timing VVT Solenoid) that is located on the right side of the alternator. I was wondering if there was a second valve for the Scion since I know some Toyotas have 2 valves.
2. I thought that the OCR valve FILTER was located just below the OCR, but when I unscrewed that 8mm hex bolt with my Allen wrench, I do not see a filter! Is the filter somehow located deep inside. IF YES, how do I get the filter out?
Thanks for any help
_____
05xboxer is offline
Old 07-19-2017, 10:56 PM
05xboxer's Avatar
Default Update
Ok...I was able to see inside the hole that the 8mm hex bolt was in. The tip of the filter is about 1/2 inch inside. I used a stiff wire to slide inside of the hole and snag the filter to pull out. I bent the very tip of the wire to make a hook. You might be able to use the right size fish hook.
The filter was clean, and the solenoid works when tested on a 12 volt battery. BUT it is possible that the valve itself may have hung up inside the shaft instead of sliding in and out easily as it should. I will know more when I replace it when my new valve arrives in a couple of days.
Anyway, I would still like to know if the 05 Scion has 2 of those Oil Control Valves or not. Thanks
05xboxer is offline
Old 07-25-2017, 01:05 AM
05xboxer's Avatar
Default Update 2
The filter screen was 90% clean so I sprayed with a can of carb cleaner anyway. Next I replaced the Oil Control thingeee. It is called an "Engine Variable Timing Solenoid" at Autozone. Car still cranks but will not start. Next I will be double checking all fuses and connections. At this point I am beginning to suspect the ECU since I got a ton of codes all at once when this first happened and vehicle failed to start. I am hoping that it is not the camshaft gear wheel since that is the one part that I may not want to chance replacing by myself... and of course it is an expensive repair.
Grateful for anyone with suggestions that may have had this problem.
05xboxer is offline
Old 07-10-2019, 12:57 AM
05xboxer's Avatar
07-09-19 it has been 2 years. The reason the car would not start was because somehow my ECU came partially unplugged....This is why I had a ton of codes. After securing it, it started right up. The only thing I can think of is that the last time it started, the heater fan blower made a loud noise like there was something rubbing on the fan cage. That problem somehow had something to do with all of this. Maybe I accidently dislodged the ECU connection when investigating the problem with the heater blower. Wasted a lot of time on something so dumb!
05xboxer is offline
targetman
03-16-2015 02:55 PM
RichBinAZ
12
04-11-2009 03:15 AM
AlfieC86
10-13-2008 06:56 PM
-lastsciontc-
03-13-2007 04:24 PM
dslroxx
11-01-2006 04:23 PM
Quick Reply: OCV Oil Control Valve (VVT Solenoid) and Filter Question
