2008 Scion xB tire pressure warning light
Old 07-24-2017, 02:55 AM
Antonioruiz's Avatar
Default 2008 Scion xB tire pressure warning light
I buyed a 2008 Scion xB and the owner told me he replace all the rims and since then the light wont go off. And i would like to know what i have to do yo fix that problem. Thanks in advance.
Antonioruiz is offline
Old 07-24-2017, 10:56 PM
DAlex's Avatar
A small piece of black electrical tape will cover up the light quite well.
DAlex is offline
Old 09-18-2017, 12:41 AM
ndillon's Avatar
I have a 2008 Scion xB and my tire pressure warning light flashes and then stays on, I tried to reset it under steering wheel but no luck. Bought new tires which I needed anyways but still on. Any ideas?
ndillon is offline
Old 09-07-2018, 02:23 PM
syncro87's Avatar
You can easily remove the little LED for the tire pressure warning from your gauge cluster circuit board with a soldering iron and some tweezers. Removing the cluster is a piece of cake, literally takes a couple minutes and a screwdriver. The cluster comes apart easily.
Scion uses the dumber of the two methods of monitoring tire pressure. Some manufacturers use a more intelligent system that relies on the ABS sensors and rotational speed differences to determine if a tire is low. Scion (Toyota) uses the ridiculous style of system with physical sensors inside the wheel. The Toyota system is inferior for a variety of reasons I won't elaborate on, but it sucks.
TPMS came about for two reasons, for the most part. Some high performance cars began to use run-flat tires back in the day, and TPMS was implemented on those to give the driver some indication of low pressure. Porsches, Corvettes, etc. More of an influence was the Firestone / Explorer debacle in the 1990's. A bunch of people drove Explorers with defective tires, and a lot of those people were less than diligent about checking their tire pressure. Drivers who never checked pressure putting on lots of miles with chronically underinflated tires that were defective from the get-go equals bad things happening. So the government came in and mandated TMPS for everyone.
I've driven for a few decades now, and I regularly check my tires, as anyone operating a motor vehicle should. I've never had an issue due to lack of TPMS on a vehicle. Actually, I can't think of anyone I know who has suffered injury as a result of not having TPMS in their car, or a single person who was saved from some awful fate by having it.
Hence, due to Toyota's sub-par implementation (internal sensor vs. ABS based) and my regular preventive maintenance on my cars, my TPMS light may have mysteriously vanished from my gauge cluster.
syncro87 is offline
Garrettthepatwa
09-02-2015 04:40 PM
SighOnTeeSee
Scion tC 1G Wheel & Tire
18
10-24-2008 06:45 PM
H-town_hero
20
07-04-2007 04:17 PM
Cranker
06-28-2007 08:55 PM
04-15-2005 06:09 PM
Quick Reply: 2008 Scion xB tire pressure warning light
