04 xA won't turn over
So I went to get gas today car was running fine went in to get a drink came out and the car wont start it tired once then stopped just had a starter put in February the battery is fine.
When the key is out the ABS light and over heat light are dimly lite. I started to pull the starter but the day got away from me. What could it be? The starter relay clicks but that's where the power seems to stop
I realize it has been nearly two weeks and you've probably got this figured out.
I would look first at your battery connections, and the connections to the starter. I've had a loose ground cause everything you mentioned in your post.
