2006 Scion tC won’t crank or start,
My Scion tC wont start or crank i have try everything and nothing work. Change the relays fuses but nothing,
all the lights on the dashboard work battery is good, starter is good too bad nothing happens when i try to start the car
Last edited by MR_LUV; 11-28-2017 at 11:08 AM. Reason: moved to Correct Forum by Moderator
Thanks
Thanks i got it to work , the ignition switch was bad. But i also have a electrical problem, i keep working on it to find out what it is
I dont know if you found out but theres a small quantity of fuses behind the obd2 port , i had a similar issue , turns out some fuses there will prevent car from turning on or staying on for that matter , i used a tester to verify both sides of the fuse had current and found 2 that had gone out .
revalina
12
12-27-2022 04:21 AM
randolph09
18
02-13-2019 05:19 PM
