Tap To Turn Signal-Does it work on the xB?
Old 11-20-2017, 01:05 AM
blueboy's Avatar
Exclamation Tap To Turn Signal-Does it work on the xB?
Hey guys, I'm new to Scions and I just got a 2014 xB.
Question, does the 2014 xB comes with a tap to turn signal?
You know the one you tap wen you wanna turn a signal when you are just changing lanes and not making a turn, and will flash three times, four, etc.
If not, can be added?
Thanks in advance
blueboy is offline
Old 11-27-2017, 04:51 PM
autobotguy's Avatar
The only thing I've found was a programmable flasher relay made my Diode Dynamics...
https://www.diodedynamics.com/smartt...er-module.html
autobotguy is offline
Old 12-06-2017, 01:35 AM
therealdede's Avatar
Originally Posted by blueboy
Hey guys, I'm new to Scions and I just got a 2014 xB. Question, does the 2014 xB comes with a tap to turn signal? You know the one you tap wen you wanna turn a signal when you are just changing lanes and not making a turn, and will flash three times, four, etc. If not, can be added? Thanks in advance
You can add it, but it's not 100% plug and play. the pinout of the flasher on the xB is the same as the CF18 flasher, but the clip is slightly different. you can either 1). Clip off the intruding plastic, and fit the relay back in place and hope it doesn't fall out,
or 2). Take apart the OEM relay and retrofit the smart tap relay internals into the OEM flasher case.
I'm receiving some goodies from TheRetrofitSource in a few days, and this is one of my modifications.
I previously had a CF18 LED flasher installed for my LED turn signals, so that they didn't hyperblink, went back to the original bulbs for a bit to test the waters, and don't like it. Back to LEDS I go.
ill post some pics and a writeup if ya want when i get everything.
therealdede is offline
