Rough/low idle 2008 xB
Old 11-26-2017, 12:44 AM
alank2's Avatar
Default Rough/low idle 2008 xB
Hi Everyone,
My 08 xB has 90K miles on it roughly and it has started doing this low idling thing where it feels really rough like it is going to die when stopped.
When driving it is fine, it has power and all is well.
Is there an idle adjustment somewhere?
Thanks,
Alan
Last edited by MR_LUV; 12-19-2017 at 11:14 PM. Reason: Moved to Correct Forum by Moderator
alank2 is offline
Old 11-26-2017, 03:01 AM
MinusPrevious's Avatar
Hi Alan
Yeah, not too sure about an idle adjustment. I would think the throttle body (rear engine area) would have an adjustment. But, I would imagine its due to an issue & adjusting an idle screw will likely not solve the issue
Ive only got 35K on mine & have not done any engine diagnostic work
Joe
MinusPrevious is offline
Old 11-26-2017, 01:58 PM
alank2's Avatar
You are probably right. Maybe I should get one of those code retrievers and see if it has any. I've got some fuel system stuff I can run through it, but I don't know if that with help as it seems plenty good when not idling.
alank2 is offline
Old 11-26-2017, 07:08 PM
Greg S's Avatar
Have you ever had the spark plugs changed, if not pull and inspect them. Also you can clean out the throttle body, that helps some times too.
Greg S is offline
Old 11-28-2017, 06:23 AM
therealdede's Avatar
unless you have a check engine light on, you shouldn't see any codes.
therealdede is offline
Old 11-28-2017, 03:56 PM
alank2's Avatar
Good to know - no check engine light.
Greg - thanks I saw a YouTube video about changing the plugs and that didn't look too bad. I'll try that next and see what that does.
I squirted some Lucas upper cylinder lube in the gas tank a couple of days ago and then drove it once and it wasn't having the problem that time...
alank2 is offline
Old 11-28-2017, 05:13 PM
What you could do if you're close to changing your oil, is you could do a seafoam clean. 1/3 can into the engine oil, 1/3 into the gas tank, and 1/3 into the intake via the brake booster line. That'll clean out any carbon buildup.
Or ya can give it the ol italian tune up for a few days...
Old 12-11-2017, 11:08 PM
parkinsonsdean44's Avatar
I have a 2012 Scion xB. My check engine light came when it was idling rough then stall. and about 20 or so codes came up. Ive change my I.A.C., MAF. and my upstream O2 sensor.
I have unhooked my battery + and- then left it alone overnight. It still idles REALLY rough (300-400 rpm) there is no check engine light because I reset it when replaced the sensors.
Do you think my TPS is bad?
parkinsonsdean44 is offline
Old 01-10-2018, 08:51 AM
xbdunks's Avatar
The low rough idle happens when u disconnect the battery. Did u disconnect the battery recently
xbdunks is offline
Old 01-20-2018, 11:02 AM
RichBinAZ's Avatar
My xB was a little rough on start up recently, so I pulled the plugs. The gaps were good still, but the white carbon deposit on the center insulator looked a bit thick.
Got a small brass brush out and cleaned off the deposit and it fired up great after that.
Perhaps the spark was tracking down the carbon to ground???
Could this be related to the low/rough idle???
A tip: I used a deep well socket to loosen the plug, then a length of fuel hose (5/16" I think by 6 inches long) with a 1/2 inch axial cut at one end to remove and replace the plug.
It slips over the insulator and has just enough grip to pull the plug up and out. Handy for those who have a plug wrench where the rubber grommet is worn out or missing.
RichBinAZ is offline
Old 09-14-2019, 02:35 AM
Ryan89's Avatar
Default Change the coolant temp sensor
As crazy as it sounds try replacing the engine coolant temp sensor located top of engine to the right (drivers side) of the head when standing in front of the vehicle that sensor is faulty tells the computer to adjust the air fuel mix ratio
depending the engine temperature so you could have multiple codes as a chain reaction to that one problem. It showed up on my Scion a 2008 as a P0117 code. Then after you replace clear the codes and see how it runs.
_____
Ryan89 is offline
Old 09-16-2019, 12:34 AM
alank2's Avatar
Thanks Ryan89 - as I remember, and I could be wrong, it seemed like this was a fuel filter or something. Working now.
My only issue at the moment is a lazy starting A/C compressor on my 2008. My 2015 had the same problem, but they replaced the compressor which fixed it. 2008 is not in warranty however. I guess there is some sort of valve that sticks int he compressor if you haven't used it in a day or so. Takes about a mile or two before it will kick in and work fine.
alank2 is offline
PARANOiAxiii
18
10-26-2022 03:25 PM
jay.diem
Scion xD Drivetrain & Power
11-06-2019 07:36 PM
ocalagtr
08-28-2014 09:39 AM
Somack_59
02-15-2008 11:00 PM
punxnotdead
01-02-2006 05:35 PM
Quick Reply: Rough/low idle 2008 xB
