Clutch release bearing w/out dropping crossmember?
Since the throwout bearing is not a HTOB bolted in and it's just held by a clip, has anyone replaced it without dropping the crossmember and everything else? It seems feasible and that would save a significant amount of labor. My car supposedly had a new clutch last year and I'm guessing the DPO just didn't spend the extra $30 on the bearing.
Havent ran into many cars that let your pull it apart and worm on it while still in the car.
you can drop the trans with just removing the axle, slave cylinder, shift cables and mount.
leaving the motor and everything eles in place tho
Out the the top or side? Doesn't require taking off all 3 mounts and supporting the engine with a support bar? That's another $120+ I don't have to spare right now.
Well duh you have to support the motor. You can ise a jack and wood on the oil pan.
i really dont know how you wjere thinking you could get the trans and motor apart without taking one out the car.
this isnt my video but shows the work
https://youtu.be/QHA5YpNiFf4
He drop the subframe but i dont believe you need to inorder to just pull the bearing leaving the trans semi in.
here another link
https://www.scionlife.com/forums/tc-tech-diy-1818/diy-clutch-flywheel-install-scion-tc-234824/
here another link
No need to be a condescending. "Well duh" I meant taking the transmission out, or at least moving it enough to clear the clutch. I've "only" been working on cars and bikes since the 90s, but I don't know the clearances on this particular model.
Yes, I've seen that video. He doesn't do things quite right and does unnecessary things like removing the sensor from the transmission entirely, opening it up to FOD, etc. He's also removing the crossmember to take it out the bottom.
I'm not talking about doing it the factory way or, like him, still the halfway-factory way.
I'm asking what's the minimum to shift it enough to get ONLY the release bearing, not the whole clutch and, like I said:
You have to clean the clutch and inout shaft so your need at lest a 7inch gap.
As said.
Remove mounts, axle and tilt it down and to the drive side. Should ne far enough to just pull out the bearing and put in a new one. If not your have to pull the trans all the way out
As said.
FormulaTwo
15
09-17-2011 02:05 PM
cburglb34
03-13-2010 04:23 PM
Ryan99FL
12-12-2008 07:01 PM
garyc_01
07-21-2008 05:17 PM
